Question about Garmin 60CS GPS Receiver
Garmin 60C not 60CS. Mapsource version 6.12.3 will not recognize the GPS. This just started, been downloading waypoints for years. USB driver is grmnusbi.sys 2.2.1.0. Tried to reload the usb drivers but could not.
    Novelist:
  • 113 Answers
I had a similar problem with another garmin model.  Problem cropped up after some sync software for an mp3 player was installed in my PC.
To get the software to recognise my GPS I had to go into my PC's task manager. (ctrl alt del).  Click on the processes tab and look for a program called "wces.exe".  Ending that process would allow the PC to recognise the GPS.  Be careful, ending the wrong process can screw up your PC.
I know this solution is a longshot, please don't give a bad rating!  :)
good luck
Posted on Oct 28, 2007
I cant send my waypoint from my gps to mapsource
Garmin now uses a new program for managing waypoint and track datum, this is Basecamp. Basecamp can be downloaded from Garmins website free of charge. Here is a link.
Hope this helps!
Apr 15, 2011 | Garmin Oregon 550t Handheld GPS Receiver
I have lost my Mapsource Setup cd for my Garmin GPS
  1. Download MapSource software updater from Garmin. The version as of December 4, 2007 is 6.13.6, and the trick also works on Map Source version 6.13.5.
  2. Unpack or extract the content of MapSource_6136.exe
    downloaded using WinRAR.
  3. From the extracted files, run MAIN.msi.
  4. Then, run Setup.exe. Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error.
  5. Garmin MapSource now installed.
Feb 02, 2008 | Garmin eTrex Vista GPS Receiver
Chat session ended by mistake. I need help with getting my Garmin GPSMAP 60 CX up and running. 1. I have successfully loaded Trip and Waypoint Manager on the computer 2. I have the unit hooked up to the...
You cannot load maps to the unit using the Trip and Waypoint Manager software. That software only does what it's called - it transfers routes and waypoints. To install maps onto your GPS, you will need Mapsource, which normally comes with the maps. Once it's installed on your PC, you hook up your GPS with a mini-USB cable, choose which maps you want transferred to the unit, and then the Mapsource software will knit the map segments together and transfer them over to the unit. Hope this helps.
Jan 06, 2011 | Garmin GPSMAP 60CS GPS Receiver
How does one update th gps?
You connect the 2720 to your pc with the supplied usb cable.
Power up the 2720 with the ac supply cable.
Then run the garmin webupdater. It will do the update.
You must have previously installed the webupdater and the usb drivers. If you use the garmin mapsource software and can connect to the 2720, to transfer waypoints, tracks, etc., then the usb drivers are already installed.
You can download the webupdater at this site:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Hope this helps.
Feb 24, 2009 | Garmin StreetPilot 2720 GPS Receiver
Unable to load coordinates for a projected waypoint
There are two ways you can load a way point.
1. Hit mark on your GPS. Push up on your rocker until the coordinates are highlighted. Once they are hit enter. From here you can change the coordinates to what ever you want.
2. If you have the software (Mapsource Trip & Waypoint Manager) you can enter the waypoint by going to "Edit" then "New Waypoint" or hit Ctrl + W as a shortcut. Once you create all the points you need, plug in your GPS and turn it on, then click "Send to Device"
Make sure that your mapsource and GPS are both setup on the same datum and lat/lon style corrdinates as well or it could throw it off.
Jan 20, 2009 | Garmin GPSMAP 60CS GPS Receiver
Connection issues
yeah , i am with garmin 196, and usb to rs232 cable and instaled driver, but it wont connect ..... anybody help ?
Aug 30, 2008 | Garmin GPSMAP 60CS GPS Receiver
Garmin ique 3600 mapsource Synch problem with XP
Are you running Vista? If so, contact Garmin for a download that allows the maps to be loaded.
Apr 13, 2008 | Garmin iQue 3600 GPS Receiver
Garmin GPSMAP 60CSx
I think all the Garmins allow to do is generate a waypoint list on your PC and upload THAT to the GPS, according to what Garmin told me about my Streetpilot C340. You also need Mapsource on the PC.
Mar 31, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMap 60 CSx USB Connection
Actually, I just solved the problem myself...
I went to Garmin's driver download site (http://www8.garmin.com/support/download_details.jsp?id=591) and got the latest USB driver (2.2.1) for the 60C. (Although, it appears that that driver pertains to all Garmin products, not just the GPSmap series or the 60C.) Installation instructions are pretty much standard for Windows drivers, so it's easy.
That: a) Garmin requires special USB drivers for their product is finicky (most USB-connectable products just connect automatically using Windows' generic USB driver), and b) my unit -- which had always worked just fine, and suddenly stopped connecting out of the blue -- remains a mystery. Nonetheless, a driver upgrade was the final step that I needed. (Although, I also swapped USB cables and upgraded MapSource, too, so maybe it's some combination of those things.)
Dec 15, 2007 | Garmin GPSMAP 60CS GPS Receiver
Trouble connecting to any computer
Hmmm..
Make sure your using a USB cable, specifically a USB cable with a mini connector on the end. Specifically, a USB cable with the second one from the left in this picture:
http://en.wikipedia.org/wiki/Image:USB_types_2.jpg
If you are using the USB port, you should have no need for setting COM ports.
Another technique you can use (which I just figured out today) was to place the Garmin Unit in "USB Mass Storage Mode". This allows you to offload saved tracks, but I don't think you can download waypoints or other things that the WayPoint Manager allows.
You can access this option via the Garmin Unit
Goto: "Main Menu" -> "Setup" -> "Interface". Press Down to get to the button "USB Mass Storage". Plug in that USB Mini cord, and you have a thumb drive!
Good Luck!
Oct 14, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin 60CS GPS Receiver Logo
202 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
