Question about Meridian Point 6 in 1 Wireless Headphones For TV Stereo PC MP3 CD DVD Player FM
Transformer 4.5 volts for emitter - Meridian Point 6 in 1 Wireless Headphones For TV Stereo PC MP3 CD DVD Player FM
Amana furnace. How do I replace a 4-wire transformer with a 6-wire?
The new transformer should have a description on the side or top. Like: Com, Color, Volt. For example, say you have `120 volts, com-white, black wire - 120 Volts. Make sure you carefully read which wires to use or have a tech come out.
Nov 12, 2015 | Heating & Cooling
Problem with panasonic ct27g5b, flyback transformer secondary volts too high changed str58041 but power supply only make whining sound when turned on
Check all the components in the main power supply board, including STR switching device, for any damage, or loose solder terminals. Check and replace the damaged component. Check the horizontal output transistor too, for short. Check it for collector to emitter, or collector to base short. It will be best to replace it with a new one, and check. For more information go to http://electronicshelponline.blogspot.com/
Dec 10, 2013 | Panasonic CT-27SL14 27" TV
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I have a coleman Evcon model AH16-0 . I am
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 06, 2010 | Heating & Cooling
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
Just quit. no seem to be burnt .does not work. no sound. fuses good. similar problem it seems like that posted jan. 15,2009
Please check +12 volts at Q809 emitter pin and -12 volts at Q810 emitter pin on power board. Also check collector voltages on both transistors and let me know to move further.
Jun 04, 2009 | Sony SA-WX700 Subwoofer
HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
ALL the next is with the tv unplugged (NO NO power)
  • resold the jungle (video processor) all around
  • following the horizontal drive pulse path and arriving to the horizontal area just after the horizontal transformer and in the base of the horizontal DRIVER there is a electrolytic capacitor (if this chassis uses this one,) Change it (maybe is dry)
  • solder all components i just told you in the last step. horizontal driver, transformer, etc
  • remember:
  • if a transistor is blowing with no reason (there is a reason: the collector receives 130 volts but cannot hold it forever, It has to be in some place. if the switching pulse doesn't arrive to it the transistor throws this 130 volts and burning itself. i hope it is help full.
Apr 15, 2009 | Televison & Video
Panasonic pt53wx53g wheres pico fuse
R7080 is mounted parallel with Transistor Q7060 (base-emitter) supplying +20 volts to STKs
R7086 is mounted parallel with Transistor Q7061 (base-emitter) supplying -20 volts to STKs
Feb 27, 2009 | Panasonic Televison & Video
Amplifier main channel non operational.
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
Sep 09, 2008 | Audio Players & Recorders
Meridian Point 6 in 1 Wireless Headphones For TV Stereo PC MP3 CD DVD Player FM Logo
Top Meridian Point Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Meridian Point Audio Player and Recorder Expert? Answer questions, earn points and help others
