Question about Hardware & Accessories
Cant read et-1 timer - Hardware & Accessories
Increase volume of the Timer on a GE Gas range
Which model of range do you have?
Ok I found the GE owners manual for this range. http://www.searspartsdirect.com/partsdirect/user-manuals/JGB700SEJ1SS-GE-GAS%20RANGE-manual
I read through it a couple of times and it doesn't mention anything about adjusting the timer volume. However, there is a GE hotline you may call during regular business hours that would probable be the best way of finding out if it can be adjusted. that number is
1-800-626-2005
GE Appliances Answer Center®
Monday–Friday: 8 a.m.–10 p.m. ET
Saturday: 8 a.m.–7 p.m. ET
Sunday: Closed
Sorry I wasn't able to find the specific answer but if this 1 800 number doesn't have the answer nobody does.
Sep 26, 2017 | GE Kitchen Ranges
After a battery change, my timer ET100C flashes 1-h8. What is the cure?
Try resetting timer.
Small round hole located just below the display... use paper clip and push and hold for 5 seconds... then reprogram timer
If functionality is not restored, then replace timer.
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET100
Gene
Water Heater Timers Save Money
Feb 27, 2015 | Intermatic 10 Amp Mechanical Indoor Timer
I cant set my intermaticet8215c
Following link has manual
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET8000
Add comments and I will answer each comment to help walk you through the settings. April 2015
Gene
Jan 17, 2014 | Intermatic ET8215C- 7-Day Electronic...
How to work a ET 321 timer
1) Copy following link to identify timer, and read possible instructions for 1-button outdoor photocell timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
2) If you have different timer, then view page for possible match, and/or add comment with clear description of timer.
Dec 21, 2012 | Hardware & Accessories
Circuit #1 has power,circuit #2 has no power
More information is needed:
Add a comment and describe product or timer, and what voltage you are using, and what circuit controls.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html
Nov 18, 2012 | Hardware & Accessories
Bonjour je veux changer l'heure sur modele intermatic et70215c envoyer document en francais merci, juleslafond@qc.aira.com
1) Je ne parle pas fran?ais.
J'utilise google translate.
http://translate.google.com/#
2) J'utilise navigateur add-on: IMtranslator
s?lectionnez le texte dans le navigateur, puis cliquez sur IMTranslate
http://imtranslator.net/ff-plugin.asp
3) paragraphes copier et coller du manuel.
coller du texte dans Google Translator
Traducteur utiliser pour aider avec le manuel
traduction n'est pas parfaite, mais il sera probablement assez bon
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70215c%20-%20english.ashx
4) Je sais comment programmer le ET70215C
Je peux vous aider
»ajouter un commentaire" et il m'envoie e-mail
garder question simple et courte
5) aussi
contacter Intermatic
Intermatic est hors ligne le samedi et le dimanche
http://www.intermatic.com/customer%20service.aspx
May 05, 2011 | Intermatic ET70215C Electronic Energy...
I have a First Alert Digital Timer, Type ET230, Model #16USW/ET. I can't find the manual anywhere and can't remember how to program it. First Alert doesn't even mention timers on their website. I don't...
I came across this page while looking for the same thing. Then I found the manual! I scanned and uploaded it to Photobucket. Click on the link to view. I know the original post is from a couple years ago, but hopefully this can help someone trying to remember how to program this timer.
Click Here For The Owner's Manual
Dec 04, 2010 | First Alert 24 Hour Timers - 2 For The...
Broken Timer knob
Hi Krusin,
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Sep 10, 2008 | George Foreman GRV660 Toaster Oven with...
Hardware & Accessories Logo
13 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
