Question about Yardman Yard-Man 13AC76LF055 38-Inch 344cc 12-1/2-HP Powerbuilt Briggs & Stratton 6-Speed Transmission Riding Lawn Mower
13.5 hp spark plug gap - Yardman Yard-Man 13AC76LF055 38-Inch 344cc 12-1/2-HP Powerbuilt Briggs & Stratton 6-Speed Transmission Riding Lawn Mower
What is the spark plug gap for Briggs 20.5 hp
For a proper answer more info is needed. Here's a Briggs site that has spark plug gaps listed. Gap is not hyper critical for running.
.030-.045 will work. The only time I've seen gap matter was when it was too close like .005, the engine wouldn't run.
What is the right spark plug and gap for my small engine Briggs Stratton
Sep 21, 2017 | HP Garden
Spark plug gap on a 2001 Pontiac sun fire 2,4 liter
Gap
For 2.4L-- Allow a gap of 1.27 mm (0.050 in).
Tighten the spark plugs to 18 N·m (13 lb ft).
Apply dielectric lubricant GM P/N 12345579 (Canadian P/N 1974984 or equivalent to the insulator boots.
Feb 19, 2017 | 2001 Pontiac Sunfire
Idles rough cylinders 13 and 5 have spark to the plug but it makes no difference when I unplug them
couple of possibilities one is that the spark plugs themselves are grounding the insufficient gap so it's not actually generating a spark other possibility is the spark plug boot or tube is our King instead of the spark plug I had two similar situation on a6 cylinder car one of them the piston ended up touching the spark plug and broke the gap another one was that the spark plug boot the long boot going into the cylinder head itself had a voltage Leak and was arching against the cylinder head good luck
Feb 04, 2015 | Cars & Trucks
Spark plug gap setting
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Spark Plug Application Chart
Spark Plug Gap NGK Spark Plugs Tech Video
http://www.yamaha-motor.com/assets/service/manuals/2000/lit-11626-13-13_50.pdf
OEM parts for Yamaha
https://scootergrisen.dk/scooterhjemmeside/download/yamaha_jog_servicemanual.pdf
Jun 25, 2014 | 2009 Yamaha Jog RR
Were is low oil sensor 13-hp.briggs
check gap on coil the gap on the points and also make sure the magnets are free of rust, the capacitor could be weak also.
Jun 11, 2014 | Briggs & Stratton Ignition Kit 2-8 HP...
What is the firing order for spark plugs on a 2006 Pontiac Vibe?
1.8L (LNK)Firing Order
1-3-4-2
Spark Plug Torque
18 N·m
13 lb ft
Spark Plug Gap
1.0-1.3 mm
0.040-0.051 in
Spark Plug Type
SK20R11 DENSO
1.8L (LV6)
Firing Order
1-3-4-2
Spark Plug Torque
25 N·m
18 lb ft
Spark Plug Gap
1.0-1.2 mm
0.040-0.048 in
Spark Plug Type
SR16R11 DENSO
Thank you and enjoy,
Lee
Sep 27, 2010 | 2006 Pontiac Vibe
Yardman Yard-Man 13AC76LF055 38-Inch 344cc 12-1/2-HP Powerbuilt Briggs & Stratton 6-Speed Transmission Riding Lawn Mower Logo
90 people viewed this question
Top Yardman Garden Experts
Dennis Key
Dennis Key
Daryl Gleaton
Dan Apthorp
Are you a Yardman Garden Expert? Answer questions, earn points and help others
