Question about 2004 Mustang Factory Wiring Diagrams
Opel corsa 1.4i firing order
Firing order is incorrect
    Genius:
  • Ford Master
  • 2,494 Answers
Try 1342or 1432. it should be stamped on the inlet manifold.
Posted on Sep 03, 2014
Back fire flames Out of carb,runs for 20secons ,1200 Datsun
incorrect firing order ---check firing order and ignition timing
valve open for inlet --check valve clearance
Oct 24, 2016 | Motorcycles
4 brl rochester carb
Backfiring is caused by either the firing order being incorrect or the engine timing is incorrect. generally backfiring through the carburetor is caused by incorrect firing order. confirm the distributor is inserted properly and double check firing order beginning with cylinder number 1.
Mar 22, 2014 | 1984 Buick Regal
97 chevy c1500 timing chain install 350 it will not run put gas intake it back fires.
Two possible errors . Check that the timing marks are correct and check the firing order of the plugs as the leads may be swapped around or the distributor has be installed incorrectly causing the firing order to be out. Do a compression test to check for bent valves.
Feb 01, 2014 | Cars & Trucks
1992 Honda CB 750 Nighthawk firing order
Hi, Glenn for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1992 Honda CB750 Nighthawk firing order Google Search
Order of spark plug wires incorrect
Honda CB750F2 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Aug 17, 2012 | 1992 Honda CB 750 Nighthawk
2004 KIA OPTIMA WON'T START AFTER SPARK PLUGS WERE CHANGES
HI. There are several areas of concern here. I will list them below. Check all areas stated in the list for faults.
Possible cuases:
1. Incorrect firing order set. On the 2.0, 2.4 and 2.7 engines. These engines are equipped with a distributor-less ignition system. This system incorporates a coil pack assembly, along with wire sets. In order for the assembly to fire correctly, the order of the wires must be set to the proper sequence. if not, the engine will not turn over, or start correctly. Make sure your firing order is correct, and make sure you have not placed a particular wire set into the wrong cylinder. I will post a picture of the correct firing order for your engine, below this list, shortly.
2. Incorrect spark plug gapping procedure. If the new spark plugs were gapped incorrectly, this will not allow for proper spark, thus, preventing optimal combustion, due to lack of fire. Check the spark plug gap using a wire gap gauge, and adjust if necessary. The gap should be 0.039-0.043 in. (1.0-1.1mm)
3. Failed coil pack assembly. This will be the worst case scenario. The coil pack supplies the necessary current that fuels each plug. The current is transferred, via wire sets.This will be the culprit if all the above areas are proven to be operational, and in good shape.
4. Failed wire sets. Replace the wire sets if faults are found at the connector at the ignition coil pack, or at the plug boot.
NOTE*
In order to provide the correct firing order for your engine, i will need the engine size and liter information, if possible. Please post this information, asap. Thanks..
Mar 24, 2010 | 2004 Kia Optima
Need fire order,spark plug wires replaced in incorrect place
For several engines....
Fig. 1: Buick-built 231, 252 V6 Engine firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
Fig. 2: Olds-built 260, 307, 350, 400, 403, 455 Pontiac-built 265, 301, 350, 400, 455 V8 Engine Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: Counter-clockwise
Fig. 3: Buick-built 350 V8 Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Fig. 4: Chevrolet-built 267, 305, 350 Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: clockwise
Fig. 5: Chevrolet-built 262 Firing order: 1-6-5-4-3-2 Distributor rotation: clockwise
Hope helped with this (remember rated this help) Good luck.
Nov 05, 2009 | 1985 Oldsmobile Delta 88
Check you firing order
Yes correct.The firing order should be cast in the top of the intake manifold to the front of the throttle body or carb.
Jun 16, 2009 | 1990 GMC Sierra
Changed heads due h/gasket ,tried to start engine however started but bad misfiring shaking etc checked leads now what ?
Hello; Sounds like firing order is incorrect. Recheck plug wires for proper cylinder match. The firing order is usually casted on the intake manifold.. Let me know, ok?
Six cylinders :153624
v-8 18436572,- 1546278 etc.
4 cyl -1342
GOOD LUCK
May 06, 2009 | 1996 Land Rover Range Rover
2004 Mustang Factory Wiring Diagrams Logo
177 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
