I dropped my unit and now the bottom half show things purple (cool colors). Otherwise the unit still works perfectly. Is the problem anything that I can fix myself?
volume keeps cutting down. Have to use remote for the cable. It will not cut volume back up but if i...
(More)
volume keeps cutting down. Have to use remote for the cable. It will not cut volume back up but if i keep pressing the up on the remote, a message comes up on the screen about warranty date and hours. I have no idea how to stop this. If i go to menu, the volume stays up until I close menu, then it goes right back down. I can only cut it up with the volume control button on the front of the tv.
No sound when connected to cable. No sound when disconnected from cable and the audio output cable...
(More)
No sound when connected to cable. No sound when disconnected from cable and the audio output cable is removed. (No static or cracking noise from speakers, zip.) Sound when connected to DVR player, and the sound IS coming from the speakers.
My 35 inch Tv does some quite random things. For instance it will turn of or on at will within...
(More)
My 35 inch Tv does some quite random things. For instance it will turn of or on at will within seconds of each other. Secondly, there are times when you are trying to turn the volume up or down, and it changes "input", and will not turn off or on without the remote. When it does that the buttons on the tv are non-responsive.
