Question about Northland 18TF-WP Top Freezer Refrigerator
Northland refrigerator noise - Northland 18TF-WP Top Freezer Refrigerator
I need a phone number for customer service for Northland Designer Series Refrigerator
This is from a manual
NORTHLAND KITCHEN APPLIANCE DIVISION Northland Corporation Greenville, Michigan 48838-0400 P.O. Box 400
And then we go to Yellow pages
Northland Corporation Write a Review Add a Photo .st0{fill:#FFFFFF;stroke:#E2E2E2;stroke-width:2;}.st1{fill:#ECECEC;stroke:#E2E2E2;stroke-width:2;}.st2{fill:none;stroke:#E2E2E2;}.st3{fill:#FFFFFF;stroke:#E2E2E2;}.st4{fill:#ECECEC;stroke:#E2E2E2;}
Be the first to review! 1260 E Van Deinse St, Greenville, MI 48838
(616) 754-5601
Northland Corporation in Greenville MI
Nov 29, 2016 | Northland Refrigerators
My Northland refridgerator seems to have a new constant humming noise like it is touching something to cause this new sound. It is running, and keeping the temperature fine, cold/freezer is good too. It...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 21, 2011 | Northland GS36RP Refrigerator
Freezer was freezing up. Technician came and thawed it up and got it cooling as it should; however, the freezer is only getting to 40 degrees. It is not making ice. It is not cold enough to keep my food...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 19, 2011 | Northland Pro-Chef Model, Three Door,...
I have a northland 42SS-WS that keeps turning off intermittently. It is now making a loud humming noise when turned on but is not cooling properly. Any suggestions?
Either your drain line to the drip pan is plugged up and you have a built up of water or ice in the machine, or the compressor is bad.
Dec 31, 2010 | Northland 36SSS Side by Side Refrigerator
My northland 48" side by side is not cooling on either reefer or freezer sides. Everything either defrosted/melted or got warm. The system is running and blowing only ambient air inside and the normal warm...
You could have something as simple as frozen evaporator due to defrost system malfuntion, bad compressor electricals or failed compressor. I believe the sealed system in that unit comes with a good warranty. I would contact Connie at the factory, 800-223-3900. She can help you find a servicer to repair it and also provide any further troubleshooting assistance you need. You can also find servicers in your area by visiting their web-site www.northlandnka.com in the support area.
Feb 12, 2010 | Northland D48 / G48 Side by Side...
My northland all refrigerator seems to be running but it is not cold
it sounds like its running,but all your hearing is the fans,you need to replace the rtc overload contactor located on the compressor body side,undo the spring clip wire unplug the rtc overload from the compressor and replace it,when you turn it on you will hear the compressor start then
Jan 16, 2010 | Northland Refrigerators
My northland refrigerator is not making ice
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 24, 2009 | Northland D48 / G48 Side by Side...
Northland 48" side by side is too warm
If you have this unit for a long time, maybe you need Freon for the compressor. you can not do it yourself.
Jul 21, 2008 | Northland D48 / G48 Side by Side...
Northland 18TF-WP Top Freezer Refrigerator Logo
Top Northland Refrigerators Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Bill Boyd
Nater13
Are you a Northland Refrigerator Expert? Answer questions, earn points and help others
