Question about Logitech X-530 5.1 Surround Sound Speakers&Subwoofer - 970114-0403 Computer Speakers
I pconnected my x530 right, only the front would work and switched wires and only the srs worked
Brother, connected my Logitech x530 5.1 suroundsound to my pc the way it describes in the manual to the sound card on the back of my pc, the 3 ports, but only the front speakers would work, not all 5 like it`s suppose to and then I swiched the jacks into different ports and this time not the front speskers would work but only the rear speakers would. now not to long ago I had a Logitech z506 that connected the way and it worked fine on same pc I just read an article that all I needed was the factory card on the back of the pc, I even tried my other pc witch is only a yr. old I get the same thing I checked 4 drivers they`re up to date. thnk you.
5 Suggested Answers
SOURCE: logitech speakers will only play on 2 speakers not 5
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
Posted on Jan 18, 2007
SOURCE: Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Posted on Dec 06, 2008
SOURCE: my logitech X530 speakers wont turn on
the fuse is soldered in the circuit board in the sub. you have to take the sub apart and get the protective metal cover off the circuit board and un solder the old one. new fuses are found at radio shack they call for a 5a125v fuse.
Posted on Feb 17, 2009
SOURCE: logitech X530 does not power all 5 speakers
put the gasoline in the logitech ang fire it..
Posted on May 08, 2009
I have a Logitech x530 subwoofer and I want to use it for my laptop. Don't what type of cable or connection to use. Help me out guys.
i had to get a 3.5mm male to 3x female 3.5mm lead from ebay that works well for me. any audio shop should have them.
Aug 24, 2016 | Logitech Audio Players & Recorders
My Logitech X530..only the front -left speaker works. Thank you.
Sounds like you have not plugged it in correctly! Have you connected the 3 mini plugs from the speakers into the adapter and then the 2 phono leads into the other end of the adapter and then the 3.5mm headphone jack into your device?
Oct 25, 2014 | Logitech X-530 70-Watt 5.1 Surround Sound...
HOW DO I GET ALL 5 SPEAKERS TO WORK ON TELEVISION?
I presume you have a sound system (surround ) dvd etc the speakers are usually connected at back these are all colour coded so should be no problem hope this helps you cheers
Jan 24, 2011 | Logitech X530 5 Speakers
How can I set my x530 speakers to work with my mp3 player?
Hi there bud , IF you just going to connect it str8 into your MP3 player ,Then it wont play out all speakers because you need a 5.1 channel sound card for it...im not too sure if you can connect your speakers straight into yuour MP3 player , i personaly have never done it...
Well hope you come right
Happy new year
Jan 08, 2010 | Logitech X-540 Computer Speakers
FRONT RIGHT SPEAKER do not turn on, no power
Sounds like the amplifier has gotten a surge of power and gotten fried. You will need to replace your system as there are no user servicable parts inside the unit. You can also try seeing if there is a fuse on the main speaker prior to getting a new one. Also check all connections to make sure your getting power too
Aug 06, 2009 | Logitech X-530 Computer Speakers
Logitech x530
I have had this a few times with customers. You might want to check if the sound cards front speaker ports are working correctly. If the card is working, the problem might be with your right front speaker, ckech that it is working. You might also want to check the settings in control panel; this has helped me a number of times.
cheers
Oct 05, 2008 | Logitech X-530 Computer Speakers
I am trying to connect my logitech x530 speakers to my computer but centre is not working correctly
If the speaker connection is in front, Maybe the front panel is audio is not working or not enabled on motherboard. Try with the back panel audio jack.
If you are sure that your speakers are right, there are following possible reasons that you are not getting the audio.
1) Volume is turned off/ low
2) Sound drivers not installed/ corrupted.
I can help you with the remote desktop assistance, if you allow.
Aug 06, 2008 | Computers & Internet
LOGITECH X530
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Aug 11, 2007 | Logitech X-530 Computer Speakers
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
