Question about Ovens
Wolf 36" dual fuel model DF364G no power. I found the circuit breaker tripped. Still no power after restting the breaker. what could be the problem?
tborn6
  • 700 Answers
SOURCE: my oven tripps the circuit breaker when turned on
When the inside of the ovens gets hot like that what happens is that the hating leements expands with the heat and when the do the short out on the side of the oven. I just noticed the date but this is still the problem.
Posted on Dec 25, 2008
barkencoa
  • 3463 Answers
SOURCE: DeLonghi EOF260 tripping the circuit breaker
It is probably an element that is causing the trouble, as it gets hotter, the insulation resistance breaks down, and if there is a weak spot or hot spot it causes the trip to operate.
I'm afraid it is a question of elmination, trying different functions, until you isolate the problem.
Posted on Feb 09, 2010
  • 523 Answers
SOURCE: We have a Frigidaire slide in ceramic stove model
replace control
Posted on May 06, 2010
Crew Dawg
  • 275 Answers
SOURCE: Wolf dual fuel range keeps
Remove power for a few minutes...plug back in to see if it responds.
If control panel still doesn't respond...it may be time for home visit by repair guy.
That control panel is the "brains" of the unit...power surge may have fried it.
Posted on Jul 23, 2011
richroth
  • 9472 Answers
SOURCE: Broil trips circuit breaker every time
I would start by replacing the breaker. They do become weak over time.
Posted on Dec 06, 2012
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
Main oven wont come on or the light but the fan does
Hi, I hope I can help you. If you're referring to the overhead fan above the oven, that fac is usually on a separate circuit. The oven itself is connected to a separate circuit breaker, hence, that is why the oven and light won't come on.
Check your circuit breaker box, and see what circuit has tripped. Check to see if there are any burn marks around the breaker before resetting it.
The reason the breakers may trip, is the breaker is old, may have the incorrect rating, or may be linked to other circuits, such that when too many items are all drawing power at once, it will trip the breaker.
Feb 02, 2016 | Ovens
Wolf wall oven heats up to about 250 to 300 and then turns off and set the breaker off
You are blowing a fuse is the house. Try spotting the fuse box and contact your landlord/electrition about this.
Jul 23, 2014 | Ovens
Hi,my belling model 664 wh is tripping out just as it reaches set temp on main oven dial,i have just replaced the main oven element, any solutions I would be grateful. Thank you.
Sounds like the amperage draw of the oven is right at the breaker size. Circuit Breakers should not be loaded more than 80%. Breakers take time to trip when they are close to the limit. IF the problem started with the replacement oven element, it may be the wrong one and could be tripping the breaker by drawing too much power.
Otherwise: Wiring or breaker not sized right, maybe another load on the breaker in addition to the oven, possible bad connections causing extra amperage, or wrong the oven element made for a higher amperage oven. In rare cases the breaker might be bad, but this is not likely.
Someone experienced needs to a) identify the breaker size b) verify the wire connected is appropriated sized c) verify the oven's current requirements and d) look for bad connections.
Normally another load would not be on the oven circuit unless a diy person changed the wiring. With those items verified, a clamp on amp meter would be used to verify actual current draw when the oven is on to ensure the load is appropriate for the breaker, wiring and oven. If at this point the load is less than 80% and the breaker still trips, change the breaker.
May 25, 2014 | Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Oven not heating properly
most common problems:
1. calrod unit not working(heating element) easy replacement
2. breaker tripped.(sometimes a double breaker will only trip one of the circuit breakers so you end up with half power)
good luck
Jul 19, 2013 | Whirlpool Ovens
Wolf dual fuel range keeps beeping after a power surge. Can not get anything on the control panel to respond.
Jul 23, 2011 | Ovens
I was heating some food and it stopped working. Where is the fuse located?
It might be that a circuit needs to be reset. Find your circuit breaker box (usually in a garage or a closet); you should be able to see a circuit that is going in a different direction than the rest--it might even be labeled). Push that circuit switch to the opposite direction. Hopefully this will work.
Mar 05, 2011 | Ovens
Burners won't turn on
first this i would check is the  circuit breaker in the house, stoves work off of a 220v dual breaker. one breaker may have tripped. the oven may still work but the burners will not.
Jun 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
11 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
