Question about Road Mice 2000 Ford Mustang GT RM-08FDMGKXA 2011 Mustang GT Wireless C
2000 gt mustang theft light reset - Road Mice 2000 Ford Mustang GT RM-08FDMGKXA 2011 Mustang GT Wireless C
2003 ford mustang gt anti theft light flashing engine will turn over but will not start
From my experience...
A non PATS coded key SHOULD not turn the STARTER...!
If ANTI-THEFT were invoked... you can attain a not start condition which the Owners Manual says must be cleared by the dealer.
A working PATS key should disable the anti theft... by turning the ignition on... ELSE try your other key.
The SecuriLock [PATS]
passive anti-theft system is not compatible with
non-Ford aftermarket remote start systems. Use of these systems may
result in vehicle starting problems and a loss of security protection.
Owners Guide (post-2002-fmt)
USA English (fus)
OWNERS MANUAL
Ford 2003 Mustang Owner Manual
SHOP MANUAL
Ford 2003 Mustang Workshop Manual
May 17, 2017 | Ford Cars & Trucks
How to reset the anti theft on a 03 mach 1 mustang gt
your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.
Jun 16, 2015 | Ford Mustang Cars & Trucks
2000 mustang gt. The theft light is on and wont
When the car is off, a slowly flashing anti-theft light is normal. When the key is in one of the on positions, that light should go off. If it thinks it detects a theft condition, the light will flash quite rapidly and prevent starting. You can also check the mileage readings in the odometer display. If you see dashes instead of numbers, that is a clue that some part of the onboard computer has gone wacky.
You already tried one of the steps that I would recommend (unlocking the door, though that may not be enough by itself. Here are a couple of things to try.
First, pray that this isn't the anti-theft computer gone awry. That is uber expensive to replace. Following that prayer ...
Verify that the battery is fully charged and showing about 12.8 volts with the headlights off and about 12 volts with headlights on. If the voltages are low, try jumping the battery to see if you can get it to start. (A low battery can occasionally cause an anit-theft fault.)
If you have another key, try that one. The chip in the first key may have gone bad. If that doesn't work ...
Disconnect the battery negative cable for 5 minutes. Reconnect, and lock and unlock the doors several times with the remote. Check to see if the anti-theft light is still flashing rapidly. If not, try starting.
Anything more than these steps will need to be handled by a qualified shop. (For example, a wire in the steering column could be damaged by the tilt mechanism, or the computer malfunctioning).
Good luck.
Sep 15, 2014 | 2000 Ford Mustang
you have to have the keys programed into the PCM again. Did you replace anything prior to this problame. If you replace the PCM, Instrument Cluster or PATS you have to take the car to the dealer to have the three systems synced back to each other. if you haven't replaced anything it is just a matter of the key is not being recognized. you will need to keys to perform the key programing and it can be done by a lock smith.
2001 mustang theft system needs reset how do i do it
reset the CPU by using a code reader . It should reset the immobiliser.
Nov 13, 2013 | 2001 Ford Mustang
Replaced started on 2000 mustang now anti theft flashing and will not crank over
try unhooking the battery for about 30 min. to reset the computer.
Feb 26, 2013 | 2000 Ford Mustang
My theft light keeps blinking on my 2000 ford mustang will not crank only gave it a boost off and it cut off will not restart
MANUSALLY LOCK BOTH DOORS THEN UNLOCK PASSENGER SIDE FIRST THEN DRIVER SIDE THIS SHOULD RESET THE ANTI THEFT
Aug 02, 2011 | 2000 Ford Mustang
2002 mustang Gt 4.6l I changed the instrument cluster and now theft lite is flashing and car wont start. The new cluster is out of a 2003 Mustang SVT
You are going to have to get the security system reset. You will probably have to contact the dealership if you don't have the code.
Feb 17, 2011 | 2002 Ford Mustang
While driving the steering will lock and all caution/warning lights come on. Stopping and restarting the engine resets all problems. 2000 mustang gt.
Sometimes these vehicles have aproblem with the alarm system or anti-theft sysytem. Might wanna take it to get checked out for any electrical issues
Feb 03, 2011 | 2000 Ford Mustang
Just replaced the ECM on a 2000 ford mustang gt and now car won't start and noticed theft light blinking..engine does crank
it could be your anti-theft need to be reprogram or the crank sensor is bad give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
Mar 05, 2010 | Ford Mustang Cars & Trucks
Road Mice 2000 Ford Mustang GT RM-08FDMGKXA 2011 Mustang GT Wireless C Logo
15 people viewed this question
Top Road Mice Computers & Internet Experts
sonofspy
Level 1 Expert
Bill Boyd
John Mangan
John Mangan
Are you a Road Mice Computer and Internet Expert? Answer questions, earn points and help others
