Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Temp wont go higher than 288 degrees - Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
2 Suggested Answers
SOURCE: stuck at 288 degrees
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
Posted on Oct 29, 2012
Jandy LJ400 temp. indicator reads 97 temp set at 84 heater wont fire when i raise the temp to 100 it lights. what do i look at
Bob, sounds like it is working as designed. If the temp indicates 97, of course it won't fire if you set 84 as the temp (97) is already above that. When you set 100, it is higher than 97 and the unit attempts to raise the temp those 3 degrees. If you don't think the water is already at 97, then there is a calibration problem with the temp sensor.
Nov 26, 2014 | Jandy Pool & Spa
Roof a/c's wont come on unless you set temp to 55 degrees
Tried another thermostat? Also check that where thermostat is mounted isn't a warm zone, that is detecting higher temperatures. Put another thermostat on wall beside it to check. Another thing is to take thermostat of the wall and let it hang and try it. I've had some where warm air was blowing/sucking past hole for wiring in wall, and throwing thermostat off.
Sep 26, 2012 | Dometic Rooftop RV Air Conditioner
Frigidaire model ES510L will not go above 288 degrees on the main oven in baking mode, any ideas?
The power outage reset the computed back to Celsius instead of Farenheit (had to change it back to Farenheit).
Saved them a ton of money... cause this could have been an easy cash grab to some crook out there.
Dec 19, 2010 | Frigidaire PLES389D Electric Kitchen Range
Stuck at 288 degrees
May 01, 2009 | Kenmore Kitchen Ranges
Rinnai 1004 heats to a temp 4 degrees higher than set temp, adjustment?
You can adjust the position of the room air sensor found on the back of the unit between the heater and the wall. It is a black rubber bulb with yellow wires. There is a few inches of extra wire you can extend higher to get a more accurate reading of room air. While you are back there, check for drafts that will give you false readings.
Sep 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
