Winsonic ws10105 bios upgrade - Computers & Internet
Maximam speed for ws10105 mother boad
the fastest front bus/ram speed is stated as ddr2 800mhz. the fastest processor it was designed to support was the pentium 4 hyperthreaded (virtual dual core), which was offered at a max of 3.6ghz.
there is very little documentation remaining about this board, do there is no evidence to suggest that it could still support a faster and/or newer processor, nor is there any documentation of its overclocking capabilities.
Sep 16, 2014 | Computers & Internet
I have a winsonic 10105 motherboard. But after the posting, system shuts down. When i enter into bios, no shutdown
Press F8 and select "Safe mode with networking" if it works then you would seem to have a driver problem, If not you may have a Failed memory problem.
Feb 17, 2013 | Computers & Internet
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
Jan 09, 2011 | Computers & Internet
How to upgrade BIOS in my XW400?
Upgrading the BIOS is an easy task but not recommended unless your computer has a problem which will be solved by a BIOS upgrade.
I assume that you are aware that a failed upgrade may render you system unusable till it is reloaded. Primary cause of a failed upgrade is a power failure so please make sure your PC has a back-up power source in case of a power failure.
The latest BIOS update can be downloaded from this website.
Download the exe file on your desktop and double click on run it. It is to be used on Win XP or 2000.
Before upgrading, check the version of your BIOS. If the version number is same as the one with you are upgrading, it means you have already the latest BIOS and it is not necessary to upgrade. The version number of this BIOS is 3.06 Revision A.
May 14, 2010 | Compaq XW4000 PC Desktop
Can I upgrade Vaio laptop bios in Dos?
BIOS upgrades are USUALLY done in DOS. Most times, you need to boot from a floppy or CD that is specific for BIOS upgrade. Some BIOS upgrade software may be apllied through Windows, but this depends on your computer manufacturer.
BTW, if your computer is running ok, DO NOT MESS UP WITH THE BIOS. You may risk ruining your laptop.
IF IT IS NO BROKEN, DO NOT TRY TO FIX IT.
Mar 19, 2010 | Sony VAIO VGN-N130G/W Notebook
Driver needed badly:
Hy there, this motherboard has an via ac'97 sound integrated.
You can have it from here:
http://www.viaarena.com/Driver/vinyl_v700b.zip
The Chipset driver is availble from here:
http://www.viaarena.com/Driver/VIA_4in1_443v.zip
No telling of integrated graphics.
Download them install and it may work.
Mar 22, 2009 | Computers & Internet
Mother board driver for ws661gx v5.0 available or not
Hi manojpalayil,
I could find a driver archive here:
http://gochinboy.wordpress.com/2008/11/14/winsonic-ws661gx-drivers-winxp-32-bit/
Good luck and greetings from Germany,
noris017
PS: plese don't forget to rate the solution! Thanks in advance and have a nice day!
Feb 25, 2009 | Computers & Internet
BIOS upgrade
Go to this site, to find bios upgrades for any motherboard.
CLICK HERE
Hope this helps, feel free to leave a Fixya rating if this has helped. Thank you for stopping by Fixya!
Feb 08, 2009 | Matsonic MS8137C Motherboard
How bios upgrade
if you go to the website for your board they will have the lastest bios upgrade and flash utility. also you will find a text file that tells you what bug fixes the newer bios cures.
be that as it may.... i just don't recommend a bios upgrade if everything is working as you can cause the computer to fail if you flash the incorrect bios etc.
Robert
Sep 08, 2008 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
