Question about Brother MFC 7840W Printer
"brother mfc j6510dw printer goes offline and i cannot print need turn printer on and off
Im running windows 7 64bit, and my brother printer keeps going offline the only way i can get it back online is to un-install then re-install it. it will work fine for about 3 days then goes back offline and i have to repeat the uninstall reinstall
SOURCE: Brother mfc is offline -
For my MFC, my PC says its ready and working properly. It really only works when I'm not connected to my cable modem. All PCs use it then. It's offline otherwise.
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: printer online then offline
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Posted on Mar 21, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
SOURCE: My Brother MFC 465N keeps turning offline. I can
mfc 465 brother unable to print
Posted on May 20, 2009
firesnake09
  • 2923 Answers
SOURCE: My printer (MFC-440CN) keeps going offline. It's
First, try printing while the printer is directly connected to the computer to see if you will get the same behavior from the printer.
If the printer works fine when directly connected to the computer, reconnect the printer via the Ethernet cable and try to perform the "ping of death" (continues ping of the IP Address of the printer).
Using the continues ping, you will see if the communication between the computer and the printer is being interrupted or not. Here's how to perform the ping of death:
DOS Prompt > ping 10.71.x.x -t > hit enter.
On the DOS prompt, you need to type ping and then hit the space bar, followed by the IP address of the printer > space bar > minus t (-t) > Enter.
____________________________________________________________
If the same problem occurs, then try to uninstall/reinstall the printer driver. If that did not help, try to clear the print spooler on your computer.
Good luck and have a great day!
Posted on Jan 08, 2010
Brother print head won't move "mfc j6510dw"
the problem of your printer is sensor found on purge unit.
Jul 31, 2016 | Brother MFC-J6510DW Multifunction Inkjet...
Brother mfc-j6510dw will not scan
This may help others with scanning issues:
I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
The black ink won't work even though its new
check if the noozles are on the catridges or on the independent print head. if the print head is seperate from catridges, them try print head cleaning. if you it cant work. then dip the print head in hot water for 5 to 10 seconds. dont dry it just put it back into the printer and try again immedeately. let me know if your problem is fixed
Jun 24, 2012 | Brother MFC J6510DW - Multifunction fax /...
Why does my Brother printer goes into Sleep mode and I can't print??
I have copied in the illustrated instructions for resolving printer status is Offline or Paused. (For Windows®) but if distorted please view here.
The printer status is Offline or Paused. (For Windows®)
Description:
To solve the problem, please see the following:
  • If the printer status is Offline:
    Check that the printer is online using the following steps:
    VERIFY THE BROTHER MACHINE IS POWERD ON AND THERE ARE NO ERRORS
    1. If the LCD screen is blank, then the Brother machine is not powerd on the machine to see if it wakes from sleep mode. If it does not, then verify that it is plugged into a working outlet and any power switches are turned to the ON position.
    2. Check the LCD screen for any error messages. An example would be "Paper Jam" or Ink/Toner Empty". If the LCD screen shows an error troubleshoot to clear the isssue indicated.
    CHECK THE PRINTER STATUS
    NOTE : These steps or screens may differ depending on the operating system.
    1. For Windows® XP Users:
      Click Start => Printers and Faxes
      For Windows Vista® Users:
      Click Start => Control Panel => Hardware and Sound => Printers
      For Windows® 7 Users:
      Click Start => Devices and Printers
    2. For Windows® XP and Windows Vista® Users:
      Right click on the icon for your Brother machine and choose Use Printer Online.
      Double click on the icon for your Brother machine => See what's printing => Printer => Use Printer Offline (Take the checkmark off.)
Note If the problem still continues, do one of the following:
  • If you find the Related FAQ's at the end of the page, click it and check another solution.
  • If you don't find the Related FAQ's, please contact Brother Customer Service from "Contact Us".
  • If the printer status is Paused:
    Right click on the icon for your Brother machine and choose Resume Printing. (If the menu reads Pause Printing, there is no problem in the printer status.)
    Double click on the icon for your Brother machine => See what's printing => Printer => Pause Printing (Take the checkmark off.)
    If this does not solve the problem,
    Double click on the icon for your Brother machine and choose Printer => Cancel All Documents.
    Double click on the icon for your Brother machine => See what's printing => Printer => Cancel All Documents
If you are using Windows Vista or Windows 7 please view here.
Trust this is helpful.
Dec 17, 2010 | Brother MFC 7840W Printer
Apr 17, 2009 | Brother MFC 7840W Printer
Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Apr 07, 2009 | Brother MFC 490cw Color Inkjet...
Brother MFC 7840W Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
