Question about Vizio VP505XVT TV
VIZIO VP505XVT Is there firmware for this tv?
I have a Vizio tv that the logo light is flashing.
Corrupted firmware. Just try a hard reset. If it do not help; d a firmware update. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail. make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset.
Sep 29, 2016 | Vizio SV470M LCD TV
I HAVE A VIZIO TV MODEL M3D550SR ITS SAYING IT HAS TO UPDATE FIRMWARE 3.12.17 IT STARTS TO UPDATE ONLY GOES TO 37% AND STOPS CAN I GET THE FIRMWARE AND DOWNLOAD IT TO A USB AND MANUALLY UPDATE IT
Yes. You should never do those updates via internet because you can toast the system with a bad download. Check your manual. You may have a _specific_ USB location on the TV for firmware updates.
Mar 12, 2016 | Vizio Televison & Video
I have a vizio tv...i can see the vizio logo light up but wont turn on...
Corrupted firmware. A firmware update is necessary. Contact any service technician.
Nov 21, 2015 | Vizio VO Televison & Video
I hav a vizio tv xvt3d474sv when I turn it on the vizio logo flashes 24 time then shuts down
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2015 | Vizio Televison & Video
Word "debug" on my vizio tv screen
Sounds like firmware corrupted. A firmware update might be necessary. Contract the authorized service center for Vizio.
Gopakumar Gopalan Google
Mar 10, 2014 | Televison & Video
I have a Vizio Model E420VL and it gets into a state which the audio does not work (from HDMI input #1) and remote control processing in the unit also does not work. I had played around with the side...
hi,
It can be difficult to get things right on the first try. With that truism in mind, Vizio Incorporated includes USB ports on their televisions that you can use to load firmware updates onto the television. Vizio has released firmware updates only for certain television models, and the instructions for installing firmware updates vary slightly by model. To upgrade your television's firmware, you need to download and copy firmware drivers to a USB flash drive and then read and follow Vizio's specific installation instructions for your model.
1. Connect the USB flash drive to your computer
2. Click the "Start" button, and click the "My Computer" icon.
3. Right-click the flash drive, and click "Format" in the menu
4. Select "FAT32" in the drop-down menu, and click the "OK" button. Windows will format your USB flash drive with the FAT32 file system.
5. Open your Web browser, and navigate to the Vizio support Web site at www.vizio.com/support.
6. Click the "Select Your Product" drop-down menu, and select your model of Vizio television from the list. A new page will open that displays available downloads for your television
7. Click the "Firmware Update" link, and save the firmware update file to your computer.
8. Click the "Firmware Instructions" link, and read the instructions specific to your Vizio television model.
9. Right-click the file that you downloaded, click "Rename," and then rename the file to the exact name that is specified in the firmware instructions 10. Right-click the file, and click "Send to" > "E: USB Drive" or whichever drive letter corresponds to your flash drive. The firmware update file is copied to your USB drive 11. Right-click the "Safely Remove Hardware" icon on the right side of the Windows task bar, and eject the device from your computer
12. Disconnect the USB drive, and plug it in to your Vizio TV's USB port.
13. Follow the steps in the firmware instructions to install the firmware update to your television.
Only you can find is the problem with firmware by udating the frimware of your tv. ok
Aug 05, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Samsung big screen tv model pcl542r has a green or red tint to picture
This is for the 50" Vizio TV,
It sound like the control board has a problem. There is two way to fix this.
- Upgrade the firmware of the control board, If you can find the firmware upgrade device.
- Replace the control board (I think this the best solution)
Feb 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Open Questions:
Vizio VP505XVT TV Logo
18 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
