Question about Polar PIM15W Ice Cream Maker
Ice maker says the tray is full it won't make ice the fan does not come on to make ice
Polar Ice maker says low water level when full of water
Replace the motor. During the cycle of the unit if the water flow circuit does not scence flow, the unit faults with a low water indication
Jun 22, 2010 | Polar PIM15W Ice Cream Maker
I need an ice cream can for a 2 quart ice cream maker #8401
Making homemade ice cream for your family can be lots of fun during the hot summer months.
  1. After preparing and refrigerating your ice cream recipe, pour chilled ice cream into cooled ice cream can.
  2. Fill ice cream can 3/4 full; mixture will expand.
  3. Insert the dasher making sure it is positioned correctly into the can indentation.
  4. Place cover on ice cream can.
For more information you can click here
May 20, 2010 | Rival 8804-BL 4 Quart Ice Cream Maker
Ice maker don't make ice, the three red lights just keep on blink
Hi, The water tray on the machine is probably broken where it connects to the motor. I have the same problem, and am trying to reach Greenway to see if I can get a replacement part. this seems to be a common problem with this ice maker.
Oct 05, 2009 | Polar PIM15W Ice Cream Maker
Polar ice maker model PIM15W
Try Greenwayhp.com look under replacement parts page 3.....The gim15 tray is the same........
Feb 02, 2009 | Polar PIM15W Ice Cream Maker
My newair A1200ss stopped making ice. i tried recycling the unit and it has ample water, but the ice tray just stays in the down position. thanks.
I have had the same problem with two different portable ice makers, the ice tray inside is broken so you will have to send it to them and get it fixed. Hopefully eventually they will make the tray out of a stronger plastic.
Nov 29, 2008 | NewAir AI-200SS Ice Cream Maker
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Polar PIM15W Ice Cream Maker Logo
Top Polar Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you a Polar Ice Cream Maker Expert? Answer questions, earn points and help others
