Question about GE 27GT271 TV
Won't turn on
When attempting to power-on the 8-year-old TV, via either the set button, or the remote, it just rapidly turns itself on/off/on/off.. back and forth repeatedly, and never does actually show a proper picture. It will continue this until the power button is pressed again. I understand this is probably an issue with the power supply, but it this something that's worth it to fix? TVs are getting less & less expensive, and it's probably about time to buy a new flatscreen anyway.
    Top Expert:
  • GE Master
  • 75,320 Answers
Check and replace damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 17, 2014
Testimonial: "Thank you for your assistance!"
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Posted on Sep 14, 2006
IrishDruid
  • 2712 Answers
SOURCE: Power button makes a click, click sound
The sound is coming from a failed flyback auto transformer. You will need to replace that.
Posted on Jun 14, 2008
  • 8457 Answers
SOURCE: 32 in ge tv doesn't turn on
It ur high voltage is dead.Ur FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to ur CRT(tv tube).That must be replace.
Posted on Sep 24, 2009
Panasonic tv
Try couple of things .hold the volume button on the tv and at same time press the menu button rapidly 3 times.if this does not get into the correct screen try holding the volume button on tv and press the zero(0) button 3 times rapidly and another is to hold volume button on tv and press zer(0) button on remonte rapidly 3 times each o fthese methods these should get you into various set up screens but be careful and take notes if you change settings .you may have to unplug or turn power off at mains and power up again to see changes
Feb 16, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Vizio LCD TV Model L37HDTV10A - I have attached a Digital TV Antenna to the proper input, but once I open the on screen display go to the DTV input and attempt to access the TV setting to program the...
Sometimes it takes a while for the TV to go through this set up such as a half hour to an hour. Just be patient an make sure the antenna is set to air.
Jun 20, 2011 | Televison & Video
I don't know if I can make it any clearer. My remote RM-PP411 suddenly stopped working. It has new battries and the use mode light lights up when any key is pressed. I turned the STR-D685 on by hand and...
Please take these actions before we try yet another universal programmable remote 1. Clean the IR screen on your tv set. It will often appear clear in view with a reflective window which often has a black, blue, or red tint to it 2. Clean the same window on the programmable remote 3. From tons of experience, I've noticed that Sony tends to provide the most compatible remote for replacements 4. Please confirm with me which codes your attempting to use when programming, and type /model number of the universal remote 5. Keep in mind that the remote that does not work as a replacment may very well be exchanged 6. Only use approved batteries for your remote and keep in mind that rechargeable batteries account for 50 percent of electronic errors 7. If your old remote simply stopped working for no reason at all, then we may have a communication problem with the tv combo set itself. 8. Ensure that the tv set is ready and able to receive a signal by setting it to the factory defaults within the settings menu 9. If we know why your older remote simply stopped transmitting the signal, we will acheive a must faster solution 10. Please attempt a fresh set of batteries in the older remote to determine the root cause behind the transmission problem 10. Check your power cord for crimping, dents, or pinched underneath unit. Each of these activities will cause power to stop transmitting to your unit 11. the digital display is not popular for having problems. 12. Ensure that you press the power on button on the digital display firmly at an attempt to power the unit on. 13. If you still have not recieved power, we will continue to troubleshoot the internal portions
Jan 26, 2011 | Sony RM-PP411 Remote Control
TV locked with blue screen
Try resetting the TV to factory settings thusly:
Turn on the TV. While holding down the RESET button on the remote
control, press the POWER button on the TV. (The TV will turn itself off, then
back on again.) Release the RESET button.
Owner's manual available here:
http://www.docs.sony.com/reflib/docget.asp?manualid=9635&template_id=1&region_id=1&DL=
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Set wont turn on from remote intermittently and occasionally turns itself off W70-2100
Does the TV turn off on it's own, or is the remote being pointed at the TV when it goes off - without you pressing the power button on the remote? If the TV goes off with the remote pointed at it (without you pressing the power button), it could be old batteries, or you need a new remote. Have you tried replacing the batteries in the remote? If it's not the batteries, have you got a universal remote lying around somewhere that you can program to operate the TV and try to operate the TV with it? If you determine that it's not the remote, it is probably something to do with the infrared remote sensor, or something faulty in the sensor's circuit board that controls the power switch. How old is the TV? If still under warranty, I would call the manufacturer and explain your problem. They will be able to assist you with any further questions you may have. The number for the manufacturer's Customer Service is located inside of the owner's manual. If you no loner have the manual, you can easily get the contact info via the manufacturer's website. Good luck, and I hope this helps...
Sep 10, 2008 | Televison & Video
Won't turn on
I have been told by the Acer Support to try two things.
1) Press the left most and right most buttons just left of the Power button continuously for 15 seconds, this is equilvalent to "rebooting" the TV.
2) Unplug all connections to the TV and leave only the power plug attached to the TV, press the Power button continously for upto 30 seconds. This will discharge any electric in the TV.
3) (Actually my discovery, not Acer Support) - Turn the TV on and off a zillion times at the back of the TV in combination with the ON/OFF button from the remote and it will ultimately turn itself back on again.
Aug 01, 2008 | Acer AL2671W 26 in. LCD Television
Tv wont turn on
How old is this set?
I guessing it is maybe 8 years? In that case I would plan on overhauling the high-voltage circuit because it is going to need it soon whether it is the problem now or not (and it very likely is). Should cost under $200 at a shop. I generally don't waste time on older dead TV's but this is a good model and worth the effort. The risk is that sometimes when the high-voltage fails, it blows up other circuits in the TV and can be a real nightmare.
Jan 03, 2008 | Sony KV-35XBR48 35" TV
Tv stuck in standby
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
Sep 10, 2006 | Sony KV-32S42 32" TV
GE 27GT271 TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
