Edf error codes d4
Do not accept the key
Stick my key in the ignition to start a saubb 9.5 and it tells me key not accepted what is the problem need help fast???
You can start your vehicle, just turn key to start. hit any button on remote, if it accepts the signal. Then car will start. You can also go to dealer to have the system checked, and find out whats wrong. Because there are many reasons why this has happened. Hope this helps!
Aug 13, 2014 | Cars & Trucks
Cannot enter letters with license key
Try turning on your Caps Lock key? Normally they wont accept letters if the key is numbers only!
Jan 11, 2014 | Avanquest My Invoices And Estimates Deluxe...
Sid is displaying key not accepted 02 saab 93 t
1. Try locking and unlocking the doors five times with the remote to reset the immobilizer.
2. Key in ON position push Open button on key fob.
Dec 30, 2013 | 2002 Saab 9-3
I have a 92 Oldsmobile Toronado that was recently broken into and my igniton was broke. And now I can't start it. I can put the key in it and turn like usual but the information center is saying starting...
I believe that your key has a resistor chip. You will need to find the resistance of your chip. Once found, go to an electronics store and buy a resistor with the same value. Follow the two wires that go from the ign switch down the steering column , into a 2 wire plug into the ign module. Unplug the connector. Plug the resistor to the module. The module will read this value and allow you to start the car.
Nov 24, 2013 | Cars & Trucks
2006 Kia Rio key won't accept code
So your saying a dealer can not fix their own products
That's their problem,now your car is there
Have at least 3 working keys for all your vehicles
Jan 21, 2013 | 2006 Kia Rio
My next question is if the original key wont start the car how do i get a vats key
you measure the ohms on the resister in the key using a digital multimeter. once you get the value you go to the dealer and ask for the number key that matches the resistance, get the key cut.
1 0.402 (acceptable range .386-.438)
2 0.523 (acceptable range .502-.564)
3 0.681 (acceptable range .650-.728)
4 0.887(acceptable range .850-.942)
5 1.130 (acceptable range 1.085-1.195)
6 1.470(acceptable range 1.411-1.549)
7 1.870(acceptable range 1.795-1.965)
8 2.370(acceptable range 2.275-2.485)
9 3.010 (acceptable range 2.890-3.150)
10 3.740(acceptable range 3.590-3.910)
11 4.750(acceptable range 4.560-4.960)
12 6.040(acceptable range 5.798-6.302)
13 7.500(acceptable range 7.200-7.820)
14 9.530(acceptable range 9.149-9.931)
15 11.801 (acceptable range 11.320-12.290)
Oct 09, 2012 | 1998 Cadillac Eldorado
Will not start
The Passive Anti-Thft System (PATS) in your vehicle prevents the vehicle from being started with the wrong key. Even if the key is mechanically able to turn the ignition lock cylinder, the digital signal from the key must be programmed so the PATS will accept the signal from the new key.
You have a couple of choices. You can change the lock cylinder out with the lock cylinder from the original steering column so the original keys can be used. You can remove the lock cylinder from the new column and have a locksmith re-key the lock cylinder to accept the original keys, then reinstall it into the new steering column. Or you can take the entire vehicle to a professional auto service facility that has the computer equipment necessary to reprogram your computer to accept the new keys.
Dec 06, 2011 | 2004 Ford Explorer
Replaced steering coulmn now it will not start
D4 lite flashes
Flashing D4 light is an error from the TCU (transmission control unit), so you got something going on with your transmission. If you want to pull the error code, remove the passengers side kick panel and look for a pair of wires with a blue connector at the end. Stick a paper clip or some other piece of wire into each hole of the connector to short the wires. Put your key in the ignition and turn 2 clicks. The D4 light will flash the code...short flashes=1 and long flashes=10. Add the number of short and long flashes to get your code. Errors are below:
0-Transmission control unit (TCU) faulty.
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
15-Kick down switch circuit shorted.
Hope helps.
Aug 03, 2011 | 1992 Honda Accord
La d4 de mi hoda parpadea pregunto? tengo k cambiar la transmicion? espero me respondan gracias.
Generalmente el codigo D4 deberia aparecer con otros codigos adicionales, es decir, encenderse el "checke ngine" juntamente con D4. Para determinar que codigo esta presentandose necesitara hacer un escaner del computador o PCM y concocer exactamente que codigo se ha presentado.
Aqui algunos detalles: Diagnostic Error Code Chart For Honda Prelude
Espero que esto le sea de ayuda, antes de pensar en comprar algun respuesto.
Mar 10, 2011 | 1992 Honda Accord
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
