Question about Samsung Washing Machines
At rinse mode, my samsung wa10f4 washing machine fills with water but does not rinse. it just continues to drain the water and displays "4E" at the panel.
SOURCE: washing machine
Hey 4E error comes in case
1. No proper water supply
2. The Outlet pipe sould be at AT LEAST 60 CM to max 90 CM HEIGHT ie to the height of the washing machine, try putting the outlet pipe to the holder at the back of the machine.
rohityadav79@gmail.cm
Posted on Feb 03, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: samsung WF7708N6W not draining. code 5e & 4e
code 5e showen washing want spin
Posted on Aug 15, 2010
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Samsung washing machine model Wa10f4..cannot spin..in a cycle wash ang rinse ok..what can i do.
There are many things that can cause a washer to not spin...the
first place to look is the belt. Is it loose or broken?
Regards,
Dennis
Aug 17, 2014 | Washing Machines
8.0 kg wa10f4 samsung diamond drum
I NEED TO KNOW WHAT SHOULD I DO WITH MY SAMSUNG 8.0KG WA10F4 DIAMOND DRUM IF THE WATER FROM THE TUB IS NOT DRAINING..AS IF THERE'S SOMETHING STOPING THE WATER TO FLOW
Jun 02, 2012 | Samsung Washing Machines
Sometimes when I turn the washer on; it continues to run the water without filling the bowl. Seems like the washer thinks its in rinse mode.
Check your drain the drain hose must be higher that the tub or it will run down the drain.
It must be going down the drain or you would have water all over the floor If the water is coming in it has to go somwhere. In rinse cycle it should stay in the tub until the timer kicks it into drain and spin.
Sep 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
48 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
