Question about BMW 2006 530 xiT
BATTERY WORKS, BUT MY BMW WONT START ON
ALARM STARTS UP, BATTERY WORKS,IN PRESS THE BRAKES AND THE CAR WONT START ON
SOURCE: bmw 325i 2004 wont start
worn't turn over
Posted on Dec 23, 2008
alicantecoli
  • 22156 Answers
SOURCE: E36 BMW 318I CENTRAL LOCKING
try locking and unlocking the car with the key 3 times slowly ,other than that i have no idea ?? another trick is to disconnect battery and join the cables together for a few minutes to discharge any capacitors that may be holding a charge in the computer..Only other thing i can think of is the main dealers who have the right connectors and software to re set it all .sorry i havent been of any help
Posted on Aug 05, 2009
  • 881 Answers
SOURCE: Car won't start after installing new battery
You should have 2 keys andthe other one is the one for unlocking the safty alarm and turns on the power to starter.
Check it out
Posted on Oct 07, 2009
  • 462 Answers
SOURCE: i HAVE A 1997 BMW 740IL CAR WONT START JUST MAKES
If the battery is good , then you need a new starter.
Posted on May 15, 2010
  • 107 Answers
SOURCE: 2006 BMW 335i coupe wont start. Key in dash, all
try using key to lock and unlock doors a few times then retry , could also be dead car battery
Posted on Jun 27, 2010
BMW e46 won't start because of the alarm.
Hi, if the car stay for long time the computer box lost memory. Now is not reading the key. You need to program your key again by BMW manufacturer. Also on bmw the alarm is connected to computer box too.
Jul 20, 2013 | Cars & Trucks
2006 bmw 330i wont start. all lights come on and when button is pushed everything shuts down and then comes back on
Check battery connections if they are good have dealer to check the crank switch that is on the brake pedal. You have to press the brake for the car to crank and if the crank switch is faulty this will happen. Exact same thing happened to a co worker on a 2010 Altima. Everything worked except when she tried to crank the car the lights would go out.
Good Luck.
Jan 17, 2012 | 2006 BMW 330i
Bmw e36 immobilised, iginition lights come on, but the starter wont turn over. how do i start the car to get it to a garage, i dont wont to pay the £70 for recovery truck
BMW E36 immobilizer Hope the following will help. Had similar problems. The transmitter buttons on keys is for central locking and alarm. Inside the key at the front there is a small electronic/magnetic chip that looks like a block. About 8mm long, 2mm deep and 4mm wide, not connected to any pc board. This is the immobilizer. It must match the receiver that is located behind the ignition switch. If it is loose and too far away from the receiver it won?t deactivate it. If you made a spare key it will switch on electrics but won?t start the car. If you don?t have an immobilizer chip any alarm shop will be able to program a new chip or install a new pair for your keys. There is a way to disable the immobilizer but rather have it fix and protect your car. I read an article somewhere (perhaps bmw e36 blog) of people removing this immobilizer. Good luck
Jul 06, 2009 | 1997 BMW 328
1998 bmw 740il will not start even with new a battery
If you checked all the fuses try putting the car in neutral sometimes the shifter gets misadjusted and wont start till the car is completely in park.If not check for a lose wire to the starter.If the car has an after market alarm you will have to turn it off before starting there should be a little buuton under the drivers dash or kick panel.GOOD LUCK
May 01, 2009 | BMW 528 Cars & Trucks
Changed 3 fuses now car wont start
you need to check battery supply most important. if the battery low voltage, cause no start. if the battery ok & strong energy. maybe the drive away protection control if this is the problem you need to bring to BMW dealer to replace control & ENCODE the control unit using SSS.
Aug 01, 2008 | 2003 BMW 325
BMW 2006 530 xiT Logo
11 people viewed this question
Top BMW Heating & Cooling Experts
cwradio73
richie46
Gil Shultz
Are you a BMW Heating and Cooling Expert? Answer questions, earn points and help others
