Question about Haier 45-Pint Dehumidifier DE45EJ-L
Unit stopped working. Not frozen coils, not clogged filter, not space around the unit, not temperature, not lo humidity.
How do I check if I need to recharge the compressor with refrigerant gas or need to replace the humidity condenser sensor
Buffalo12980
  • 625 Answers
SOURCE: Haier HDN655E unit runs but compressor won't kick in
use a jumper cord and go directly to the compressor to see if it will run. if it don't run, open up the motor box and see if there is a klixon overload inside. this should be normally closed. if it isn't replace it. the klixon is a thermal overload cutout. it usually trips because of high winding temperatures and protects the motor inside. the compressor is a hermetically sealed unit. no, or little freon will cause the motor to overheat.
Posted on Aug 21, 2007
heatman101
  • 43501 Answers
SOURCE: The unit turns on and appears to work, but no water is collected
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Jun 03, 2010
heatman101
  • 43501 Answers
SOURCE: HDN455 worked fine last fall.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Posted on May 27, 2011
heatman101
  • 43501 Answers
SOURCE: My dehumidifier ices up and its not the room temp.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Jun 15, 2011
  • 11800 Answers
SOURCE: I have almost brand new
I'm assuming that this isn't a Timer issue - make sure it's off.
LO signals that the humidity is set to the minimum available setting - 30%. Normally that should keep the unit continuously working since the humidity in a room never drops so low, unless you live in a desert.
Try raising it a bit (up to 50) and see what's happening. If the unit doesn't starts then the defect is in the control board or the compressor - you will need to open the unit and verify that the power is delivered to the compressor and its starter coil. For that you will have to check its starting capacitor. This service manual will help you
http://www.retrevo.com/d/df/document.pdf?doc=daa28f4e2ec0b9179acf8d9f9672a0ed&ts=1312144540907&rk=0.22809628064164034
But i must warn you: if your unit is brand new you shouldn't touch or open it or the warranty will be voided - in that case contact the ones that sold it to you or the company that is providing the service, they will pick it up and fix it for free.
Posted on Jul 31, 2011
The motor is still running fine, but the dehumidifier is no longer extracting water from the air and the water container is not filling.
John, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 19, 2011 | Haier 45-Pint Dehumidifier
My 25 pint frigidaire humidityfiyer stops after a few seconds of going i dont here the conpresor start.
Ellen, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(no LED screen), set the humidity extraction knob on Maximum.
problem.
I hope this helped you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 22, 2011 | Frigidaire FDL25P1 Dehumidifier
Unir ran good for 8 months then cut off with current humidity reading LO. Humidity is not LO. Have to set below 40% then runs all the time. The AUTO humidistat sensor must be broke. 1 year...
In addition to a faulty humidistat sensor, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
problem.
If none of the above solves the problem, contact Haier Customer Support
1-877-337-3639, before your warranty expires.Haier units will generally show an E1 code if a sensor or circuit is faulty and unit will not run at all.
I hope this helped you troubleshoot & solve the problem
Aug 11, 2011 | Haier DE65EJ Dehumidifier
My 54501 stopped taking water out of the air
Kassy, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
problem.
I hope this helps you to troubleshoot and solve the problem. Please let me know.
Jul 18, 2011 | Kenmore 54501 Dehumidifier
Dehumidifier runs continuously but but no water comes out. I cleaned the filter and behind the filter. Plenty of space on sides and back. Was running fine right before it stopped dispensing water. ...
Bill, There are 5 basic, but solvable reason for what you described. You have already eliminated 2 of them. But the rest still apply. Especially # 1.
level
in basement applications . Raising the unit up off the floor,
problem.
I hope this helped you further troubleshoot and solve the problem. Please let me know. Thanks.
Jul 08, 2011 | Goldstar Dehumidifiers
Ours stopped collecting water
Linda, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manual control
unit, turn the humidity extraction knob to Maximum.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
level
problem.
Hope this helped you to troubleshoot & solve the problem.
Jul 05, 2011 | Fedders A7DH45B2A Dehumidifier
It appears the dehumidifying function no longer works. fan works, all other controls. does not produce any water. has been attached to a hose for over 1 year. only use in humid weather. 1 foot clearance....
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2 .
in basement applications level. Raising the unit up off the floor,
problem.
Hope this helped you to troubleshoot and solve the problem.
Jun 23, 2011 | LG LHD459EL Dehumidifier
Runs for 5 seconds then stops
Debbie, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2
problem.
Jun 22, 2011 | Kenmore 54351 Dehumidifier
My LG Dehumidfier 3850A20500H has stopped pulling moisture from the air it still runs but no wataer in the bucket what could be the problem? this starts happening after 1 year of purchase.
There are several things that can cause the problem you described. Most of which are easily remedied.
1. The humidity/moisture extraction level is set to high. Lower it to 35%
2, Air intake filter is dirty or clogged. Remove and clean the filter.
3. Refrigerant coils on the back of the unit are dirty and need to be cleaned.
4. Not enough clear air space around the unit. Maintain at least a minimum of 12" of clear air space all around the unit.
5. Unit is operating in a room that has an ambient air temperature at floor level, of between 40 -60 degrees F. Most dehumidifiers don't work well between those temperatures. Raise the unit up off the floor on to something sturdy enough for the weight of the dehumidifier when the bucket is full.
The above are the top 5 things that can cause a dehumidifier not to work properly. Fortunately, none of the solutions require any major repair to the unit.
Hope this helped you to further troubleshoot and solve the problem.
Jun 06, 2011 | LG Dehumidifiers
My machine is running but no water is being collected. The model number on my machine says DE N 500 P
Several things can cause your problem:
Dirty or clogged air intake filter. Remove and clean the filter according to the Owner's Manual instructions.
Dirty coolant coils. Clean and dry the coolant coils.
The humidity extraction level is set to high. Lower the level to 35%
Not enough free air space around the unit. Maintain at least 12" of air space around the entire unit.
The ambient air temperature at floor level is to cold (between 40 - 60 degrees F). Raise the unit up off the floor onto something sturdy enough to handle the weight (including a full tank of water) and the vibration during operation. This happens frequently in basement applications.
Depending on the age of the unit, the refrigeration coolant may need to be recharged.
The humidity sensor has failed and needs to be replaced.
All of the above are where you start troubleshooting and hopefully solving the problem.
Jun 01, 2011 | DeLonghi DE500 Dehumidifier
Haier 45-Pint Dehumidifier DE45EJ-L Logo
32 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
