Question about Garden
Sinnis apache starter clutch
Replace starter clutch sinnis apache
How to cool my Apache rtr 160 engine
Hi, Krishna for overheating issues the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Top 10 things you need to know about the 2012 TVS Apache RTR 160 180
https://www.tvsmotor.com/pdf/Manuals-Apache-RTR-160-NEW.pdf
Life On 2 Wheels
TVS Apache RTR 160 2010
TVS Apache Wikipedia
Mar 10, 2017 | 2010 TVS Apache RTR 160
Why does my TVS Apache 150 overheat?
Hi, Hasan and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.complaintboard.in/complaints-reviews/tvs-apache-rtr-180-l57056.html
http://www.motorcycleforum.com/129-first-bike-new-rider/192586-tvs-apache-rtr-engine-overheating-along-increased-idling-rpm.html
TVS Apache 150 2011 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.tvsmotor.co.id/images/catalogue/docs/apache.pdf
https://www.tvsmotor.com/manual-download.asp
Jan 02, 2017 | 2010 TVS Apache 150
What is the valve clearance on Suzuki GN 125
Hi, Robbie for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://diversionclub.proboards.com/thread/15171/engine-suzuki-gn125-valve-clearances
Suzuki GS GZ 125 Sinnis Apache Valve Clearance and Cam Chain Tension
Suzuki gn 125 1987 2001 Service Repair Manual Download Download Manuals...
OEM parts for Suzuki
PDFmanual co on Twitter
Dec 03, 2016 | Suzuki Motorcycles
2012 Apache RTR 160 HyperEdge the neutral light is not on when it is in neutral, the electric starter will not work without the clutch lever pulled in, what is the problem?
Hi, Sushant the neutral light could be a burned out bulb, faulty neutral light switch or the wiring in between, the clutch lever has a safety switch so you can't start the bike in gear for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Common Problems with Bikes and Their Solutions
TVS Apache RTR 160 Long Term Ownership Review By Sabi
RTR 160 Service Manual
Apache RTR 180 User Manual
Nov 02, 2016 | 2011 TVS Apache RTR 160
How to change clutch plates for apache 180cc
Hi, Teddy for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your TVS, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.xbhp.com/talkies/help-me/20312-clutch-plate-wear-apache-rtr-160-a.html
Apache RTR 150cc Clutch plate Changing
Tvs Apache Rtr Help Guide Clutch Adjustment by Mandy Newcity
http://nexgenbikes.com/site/wp-content/uploads/2011/03/TVS_Apache_RTR_180_Service_Manual_Internal_training_manual.pdf?2fb5c5
Aug 18, 2016 | Yamaha Apache RTR 180 Motorcycles
Qingqi scooter
I am having the same problem and I am having a hell of a carry on trying to get the v5 for my sinnis eagle as it's down on the dvla as a Qingqi varient so I am really confused I know after doing some research Qingqi go by the name of sinnis in the UK but it's really confused me and I have been trying to get the v5 for 4 months now!!!!!
Jun 23, 2014 | 2010 Qingqi Variant QM125T10R
I have an apache 110cc quadbike , it starts and runs fine but won't pull off from a standing start if ya put full throttle on it just creeps forward but if you pick back wheels off the floor it spins...
If the engine doesn't slow down or bog when you try to pull away, then it is indeed the clutch. If you have fitted a new clutch, you either have it assembled incorrectly, or it is badly adjusted. There are generally two adjustments on a clutch, one on the centre push rod, and another for cable slack.
However, yours has fully automatic centrifugal transmission but it still has adjustment that needs doing.
Mini ATV The Apache 110cc
check this link for clutch adjustment info on page 13 and 14
http://www.rpmfactor.com/motorzone/ATV_110manual.pdf
general info and videos.Lots have he same problem
apache 110cc quad bike clutch adjustment Google Search
manual
Aug 19, 2017 | 2006 Keeway Hurricane 50
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
