Question about Eiki LC-XL200 6000 ANSI lumens XGA Projector - Power Zoom and Focus Lens
All lights flashing
Turns off and all warning light are flashing
I have airbag warning light on it flashes once followed by nine flashes then stays on. How do I fix
Guess, wild guess, that your airbag is not functional? Maybe you should do a scan to your car's computer..
A general warning, whe any of those light turns on and you can't find any explanation, is to do a computer scan.
Oct 12, 2015 | Cars & Trucks
In my 2006 ford fusion 2.3L whenever I put my key in the ignition and turn it a weird solid ringing sound start and stops 5 seconds later hat could it be?
Not surprisingly, many others have experienced problems with the ignition switch on this car. Historically, it is not a sound, but that the key is stuck in the ignition. http://repairpal.com/key-will-not-come-out-of-ignition-570 Your problem sounds different, but it may be related. Although I do not recommend the fix in the link above, it is possible the previous owner of your car did perform this fix and it has resulted in the problem you now have. My better guess is that the chime/buzzer has failed due to moisture or dirt and is no longer producing the sound that it should, but instead is altered to the ringing you describe.To disable follow these instructions:
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
Step 3 must be completed within 50 seconds after the safety belt
3. For the seating position being disabled, at a moderate speed, buckle
then unbuckle the safety belt 9 times, ending in the unbuckled state.
(Step 3 must be completed within 50 seconds after the safety belt
warning light turns off.)
After Step 3, the safety belt warning light will be turned on for three
seconds.
4. Within 10 seconds of the light turning on, at a moderate speed, buckle
then unbuckle the safety belt.
This will disable the BeltMinder feature for that seating position if it
is currently enabled. As confirmation, the safety belt warning light will
flash 4 times per second for 3 seconds.
This will enable the BeltMinder feature for that seating position if it
is currently disabled. As confirmation, the safety belt warning light will
flash 4 times per second for 3 seconds, followed by 3 seconds with the
light off, then followed by the safety belt warning light flashing 4 times
per second for 3 seconds again.
I hope this helps. Good luck.
Jun 12, 2014 | 2006 Ford Fusion
Jetta Warning Light
It says that your vehicle is low on coolant.Get the coolant level checked.If low has to be changed.
------------Check out few help links related to your issue.Click the link below:---
Service 4wd warning light on Dash? http://howtobyme.blogspot.com/2011/11/service-4wd-warning-light-on-dash.html
Car Turns OFF due to low oil pressure warning light? http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
Hybrid warning Light ON? http://whatisbyme.blogspot.in/2012/05/2005-toyota-prius-hybrid-warning-light.html
Order Coolant Bypass Tube? http://whatisbyme.blogspot.in/2012/05/1991-toyota-camry-order-coolant-bypass.html
Coolant Leak? http://technoanswers.blogspot.in/2012/04/1994-toyota-camry-coolant-leak.html
COOLANT LEAK AT DRIVER SIDE NEAR FIREWALL? http://schematicsdiagram.blogspot.in/2012/04/2006-cadillac-dts-coolant-leak-at.html
MAF, IAT, MAP and Coolant Level Sensor problem all together? http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
Engine Coolant Temperature (ECT) Sensor Replacing? http://schematicsdiagram.blogspot.com/2011/12/gmc-engine-coolant-temperature-ect.html Loosing Coolant? http://whoisbyme.blogspot.in/2012/06/loosing-coolant.html
---------- Coolant temperature sensor dies again and again?
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
----------- Where to Add Coolant? http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
------------ Blue Water Warning Light on Dash? http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
Oct 09, 2012 | 1995 Volkswagen Jetta
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Warning light to the left above temp light, red and yellow snow flakes yellow in colour, no audio warning, not flashing, 2007 ford mondeo
It is an outside temperature warning light. Turns yellow when the temperature gets to around 5 degrees and then turns red with the temperature gets to around 0.
Mar 06, 2011 | Ford Focus Cars & Trucks
S80 T6 No oil pressure warning light flashes when
make sure the oil level is up to full. sorta sounds like its low and when you go around a corner the oil sloshes away from the pickup tube
Apr 03, 2010 | 2000 Volvo S80
How to disable seatbelt alarm on 2003 F-150?
There is a procedure in the owners manual on page 110.
BeltMinder activation and deactivation procedure
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE.)
2. Wait until the safety belt warning light turns off. (Approximately 1–2 minutes.)
• Steps 3–5 must be completed within 60 seconds or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled
• After step 5 the safety belt warning light will be turned on for three seconds.
6. Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
• This will disable BeltMinder if it is currently enabled, or enable BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by the safety belt warning light flashing four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by:
• The safety belt warning light flashing four times per second for three seconds.
• Followed by three seconds with the safety belt warning light off.
• Once again, the safety belt warning light will flash four times per second for three seconds.
9. After receiving confirmation, the deactivation/activation procedure is complete.
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Dec 20, 2009 | 2003 Ford F150 Regular Cab
Audible seatbelt warning keeps on sounding on my 2005 f150 ford truck
From the F-150 Forums, since I just bought one and this worked!
This is straight from my 2009 f150 owners guide
Preperation
1. the parking brake is set
2. truck in park
3. ignition switch is in off position
4. both seat belts are unbuckled
Disable Belt-Minder
1. turn the ignition switch to the on position, DO NOT START THE ENGINE.
2. wait until the safety belt warning light turns off. (approximately 1 minute).
* step 3 must be completed within 50 secs after the safety belt warning light turns off.
3. buckle then unbuckle the seat belt nine times, ending in the seat belt unbuckled.
* after step 3 the restraint warning light, (airbag light) will turn on for three (3) seconds.
4. within approximately seven (7) seconds of the light turning off, buckle then unbuckle the safety belt.
* the restraint system warning light will flash four, (4) times per second for 3 seconds for confirmation
you can do this for the passenger side also!!!
*NOTE
in step 3. after three times buckling and unbuckling the restraint warning light lit up in my truck. SO I WENT TO THE NEXT STEP, (STEP 4). waited 3 seconds and i buckled and unbuckled.
in the buckle /unbuckle procedure do it some what slowly and watch for the light. it may not take 9 times.
__________________
May 08, 2009 | 2005 Ford F-150
Ps3 when turning on green light yellow light flashes red then turns off
this is known as yellow light of death u could call sony for a repair which cost 150$ or fix it yourselve with a video on youtube.
Warning first option means u lose your data
Warning second option requires a skilled craftsman
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
Eiki LC-XL200 6000 ANSI lumens XGA Projector - Power Zoom and Focus Lens Logo
54 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
