Question about Kenmore 64802 Top Freezer Refrigerator
What is the rated amperage of this model. - Kenmore 64802 Top Freezer Refrigerator
Recharge Coby 707 mp3 player. Can I use recharger wall adapter input 90v-240v output dc 4v-8v? Is there a limit how log it can be recharged?
If you use a recharger other than the original, make sure that the voltage and polarity of unit is the same to one being replaced. Try to use one with a similar amperage as the original. Look for amperage rating of your batteries and then divide that by the amperage out on your charger to determine a safe charge time since you do not know if the replacement charger has an auto shut off - u do not want to overcharge the batteries and damage them.
Aug 31, 2015 | Coby Televison & Video
Goodman a.c. ck361a has new fan motor and capacitor. Comes on runs great 10 min and fan shuts off but compressor on
Its probably drawing high amperage causing the motor to overheat. It may have the wrong size capacitor or weak capacitor. Or it is the wrong HP (horse power) or RPM. If you had a clamp on amp meter you can check the amperage by clamping around the L1 (normally the black) wire. Then check the amps that the motor is rated for (labeled on motor and box it came in). The amperage should be lower than it is rated for. Example... Amp meter reads 1.2a clamped around the L1 wire (left side of contactor) and motor rated at 1.5
If L1 is greater than 1.5a it will over heat. The new motor should be rated the same as the old HP, RPM & VOLTAGE.
Jun 11, 2015 | Goodman Heating & Cooling
What is the compressor amperage for Frigidaire Refrigerator?
look at data plate on compressor it will have a fla rating & lra rating one is full load amperage one is locked rotor amperage.
Jun 12, 2014 | Goodman Heating & Cooling
Where can I find fuses for Wurlitzer multimatic percussion organ
Go here:
http://www.littelfuse.com/products/fuses.aspx
They will recommend a dealer near you that will sell you what you need. You will need to describe the fuses, eg: amperage rating, voltage rating, type and length, etc.
Apr 13, 2013 | LG Audio Players & Recorders
My 1996--windshield wipers,radio,cruise control and power windows. Dont work Is there a fuse that control all these that function ?
Fuse Block and Convenience Center
Print
See Figures 1 through 5
For 1988-93 models, refer to the wiring diagrams for fuse application and amperage ratings.
Fuses protect all the major electrical systems in the car. In case of an electrical overload, the fuse melts, breaking the circuit and stopping the flow of electricity.
The fuse block on most models covered by this section is located under the instrument panel to the left of the steering column. The fuse block should be visible from underneath the steering column, near the pedal bracket.
Fig. Fig. 1: Some models may use an underhood fuse/relay panel
If the panel is not visible, check for a removable compartment door or trim panel which may used on later models to hide the block. This panel is usually located on the left end of the instrument panel.
The convenience center is located just below the instrument panel on the drivers side. It contains individual relays such as the seat belt and ignition key alarm, and flasher.
On newer model vehicles there is an underhood fuse/relay center contains both mini and maxi fuses, as well as some relays.
If a fuse blows, the cause should be investigated and corrected before the installation of a new fuse. This, however, is easier to say than to do. Because each fuse protects a limited number of components, your job is narrowed down somewhat. Begin your investigation by looking for obvious fraying, loose connections, breaks in insulation, etc. Use the techniques outlined at the beginning of this section. Electrical problems are almost always a real headache to solve, but if you are patient and persistent, and approach the problem logically (that is, don't start replacing electrical components randomly), you will eventually find the solution.
Each fuse block uses miniature fuses (normally plug-in blade terminal-type for these vehicles) which are designed for increased circuit protection and greater reliability. The compact plug-in or blade terminal design allows for fingertip removal and replacement.
Although most fuses are interchangeable in size, the amperage values are not. Should you install a fuse with too high a value, damaging current could be allowed to destroy the component you were attempting to protect by using a fuse in the first place. The plug-in type fuses have a volt number molded on them and are color coded for easy identification. Be sure to only replace a fuse with the proper amperage rated substitute.
Fig. Fig. 2: Fuse panel cover-1991 model shown
Fig. Fig. 3: The fuse panel cover is located at the drivers side of the instrument panel. Remove the panel to access the fuses-1996-98 models shown
Fig. Fig. 4: Fuse application and amperage ratings-1994-98 models. Refer to the wiring diagrams for 1988-93 models
Fig. Fig. 5: Underhood fuse/relay panel applications and ratings
A blown fuse can easily be checked by visual inspection or by continuity checking.
A special heavy duty turn signal flasher is required to properly operate the turn signals when a trailer's lights are connected to the system.
REPLACEMENT
  1. Locate the fuse for the circuit in question.
When replacing the fuse, DO NOT use one with a higher amperage rating.
  1. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
  2. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
Mar 11, 2013 | 1996 GMC Yukon
LG Range LRE30453ST quit working. Breaker in panel shows appropriate voltage rating, range receptacle shows appropriate voltage rating, and power cord connection shows appropriate voltage rating. The...
I can tell you aren't familar with house wiring. So we will start from the beginning. Circuit breakers are rated by the AMPERAGE that it can handle. When there is a current surge above the rated AMPERAGE the breaker is supposed to trip. When the breaker trips it doesn't always trip all the way to the side, sometime it looks okay so shut the circuit breaker off and reset it and then do it again to make sure you did it right the first time. If that does not cure your problem you might have blown your thermal fuse (Item #5016) or blown the power control board (Item #5070)
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Range-Parts/Model-LRE30453ST/3204/0124111/F0903017/00005?blt=06&prst=0&shdMod=LRE30453ST
But since the display screen is also completely blank it could be one of the PCBs in the control panel.
Aug 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
2004 F-150 Maxi fuse, where is it and what amps?
If you look in the fuse block under the hood you will find several of them. They will be different colors for different amperages and labeled with there amperage rating (40, 50, 60, etc). ind the one that is blown and replace it with the same color and amperage rating and you should be good to go.
If it blows again let me know what is not working and I'll try to help you further.
Apr 26, 2011 | Ford E-150 Cars & Trucks
Whenever i try and turn on unit the breaker pops?
You need to check the maximum amperage the A/C units pulls and compar it to the breaker amperage. The breaker amperage needs to be greater than the A/C amperage. Also A/C's draw more than the rating when they first kick on, so a 15 amp A/C should be on a 20 amp breaker and so on.
Jul 12, 2010 | Heating & Cooling
Tonage or BTU/hour rating from Ruud name plate
See this link
http://www.epinions.com/specs/pr-GE_Zoneline_AZ55H07D_Air_Conditioner
Its say 7100 BTU/hr
Jun 05, 2009 | GE Zoneline AZ55H07D Air Conditioner
Caravan extractor fan
Replacement fans are based on size measured by distance between mount holes horizontally in millimeters and amperage. Connectors are another issue in your case. You may have to splice and insulate that splice properly to connect a replacement fan with your old connector. And Amperage rating is not too much of an issue so long as that replacement fan is rated equal or higher than the original. Fans can be found through NewEgg or CyberGuys on the Web.
May 08, 2008 | Gateway FPD2275W LCD Monitor
Kenmore 64802 Top Freezer Refrigerator Logo
12 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
