Question about Canon PowerShot A510 Digital Camera
Can i use an 8gb memory card in a canon powershot 510
I have a canon power shot 510 and i just bought an 8gb memory card is it compatible with this camera
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
old marine
  • 2005 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
Steve5
  • 423 Answers
SOURCE: Will sd850 take an sdhc card?
Yes, your SD850IS will take an SDHC card.
Posted on Jun 05, 2009
leecom72
  • 4806 Answers
SOURCE: Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Posted on Sep 03, 2009
  • 102366 Answers
SOURCE: Can I use 8GB SD cards in my Canon Powershot A620
The A620 uses MMC and SD cards. SD cards max out at 2GB in size. Larger cards are actually SDHC or SDXC cards and will not work in the A620.
Posted on Jan 11, 2011
I am getting memory card error with canon powershot a410
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
Sep 23, 2012 | Canon PowerShot A410 Digital Camera
`i bought a canon Power shot A3150 IS camera and a memory card all the pics i took now have a question mark with unidentified image and a question mark where the picture should be also it says there is no...
Same problem here on a Power Shot A3150 IS with a 8GB micro SD.
All worked well, then bom, only unidentified images. But the camera doesn't tell you unless you review the images...
Tried 5 recovery softwares dso far, some recover the images into a bmp, which then also says unidentified image... Even the camera can't read them.
And if I take a movie, I get an ASCII chaos in the folder the images are recorded in. No solution so far.
Aug 16, 2011 | Canon PowerShot A3100 IS Digital Camera
I bought a memory card San Disk (SDHC) 4 GB and when I put it into my Power Shot A 700 says memory card error. What can I do?
the reason you are getting the error message is because your camera is compatible with a maximum capacity of 2gb. try to have your sd card replaced to a 2gb instead.
Sep 11, 2010 | Canon PowerShot A700 Digital Camera
Is not a problemasking if my canon ixus 8015 was compatible in 4GB or 8GB sd memory card?
SD cards top out at 2GB. The IXUS 80 IS is compatible with SDHC cards, 4GB and larger.
Jun 27, 2010 | Canon PowerShot SD1100 IS Digital Camera
I have a cannon power shot SD600. I bought a memory card, and the camera says memory card error. I can't even fomat the card because the function won't high light.
Did you get an SDHC card? The SDHC protocol was developed after the SD600 came out, and the SD600 is not compatible with it. Use SD cards with a maximum of 2GB storage capacity.
May 24, 2010 | Canon PowerShot SD600 Digital Camera
My camera shows card locked. I don't know how I did that. canon power shot a520. Any suggestions?
Take out your memory card from the camera and then inspect a small or tiny switch. This is the card lock. You need to move it the other way around to enable write back on the memory card.
Hope this helps you out.
Dec 21, 2009 | Adorama T-Thread Adapter Kit for the Canon...
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Jan 09, 2009 | Canon PowerShot SD600 Digital Camera
+driver for canon powershot a 40 on vista
I had same problem. Called Canon and found out A40 is not compatible with Vista so there is no driver. But you can download pics to your Vista by purchasing USB Memory Card Reader/Writer you can find at Walmart for about $12.00. You put your Flash card in device and has USB that plugs in computer for downloading pics.
Oct 16, 2008 | Canon PowerShot A40 Digital Camera
Canon PowerShot A510 Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
