I have two problems with my 93 lexus es 300. The passenger side door will not lock. The remote or the key will lock and unlock all the doors but that one. I have removed the panel and nothing is bent and everything moves when you hit the remote or use the switch but it will not lock. The other problem is I was looking at the driver side door to compare and I pushed the locking mech closed on the edge of the door and now it will not release so I can not close the door.
SOURCE: left front door auto lock-unlock only buzzes. How remove door?
thei are screws in the door hidden by caps that you need to take off the door and near the mirror shoud pop off
SOURCE: Drivers side door wil not unlock
There is lock linkage inside the door panel. many of the parts are plastic and are designed to break if someone attempts to break into your car (I had this happen to my 87 camery) I replaced the green plastic "knuckle" and it fixed it.
SOURCE: 2005 honda accord doors will not open with remote
need an actuator for the driver door need more info go to collisionrepairadvice.com for how to do it yourself
SOURCE: Drivers Door Lock Problem
You will probably need to replace the power door lock actuator.
Here's a link to one similar to yours.
http://autorepair.about.com/library/a/1g/bl467g.htm
You can probably get a used one from a salvage yard.
Try this site to find one near you:
http://car-part.com
If you need more help post a comment.
Tim
SOURCE: central locking on megane 2000
is yours the renault keycard to start and open doors?if it is a know these cards can go faulty.they were bad on renault laguna.the switch breaks off the board inside card.can be soldered back on.think you can get replacement switch kit on ebay with instructions how to fix.need someone who can solder with some eletronics knowhow.if not not sure sorry
