Question about Samsung HT-P10 Theater System
Volume very soft even if turned to max
All 5 speakers work, but the volume stays low even when turned up to maximum (ie50) both radio and DVD's are affected checked "sound edit: checked wiring all good
shanth
  • 108 Answers
SOURCE: Poor Sound
Audio amplifier IC faulty that why you get very low volume. Else check audio driving circuit to the audio power amplifier. Contact service centre. as there is no rectification process from user part
Posted on Dec 22, 2007
  • 50 Answers
SOURCE: samsung g-600 volume problem
In the left side of the phone you have buttons that allow you to control volume during the call.Try to set it to the maximum
Posted on Sep 10, 2008
SOURCE: The side speakers in my theater system are not working
I found the cat had eaten through the wires behind the cabinet.
Posted on Dec 23, 2008
JAN_yuanjia
  • 470 Answers
SOURCE: Can barely hear sound even though volume is max
thebuzzer of your phone is defected, replace itand replace also the earpiece
Posted on Apr 09, 2009
  • 3 Answers
SOURCE: We have a Samsung HT-TZ215 Home Cinema system,
It may also come up with protect, there is a mod to the power supply. It wouls need to go into a service center to be fixed
Posted on Feb 08, 2010
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Jun 03, 2015 | Boston Acoustics Horizon Solo Clock Radio
Why is my volume low in my 2004 pontiac Grand Prix? I am trying to install a pioneer fh-x700bt and the volume is really low even on max volume you can't really here it. I need help
If you are replacing the factory radio with this there are two issues that could be causing you grief. First, the radio only has 14 watts RMS power output. This is rather low by standards. Additionally, that is factored into a 4-ohm speaker load. Chances are that the factory speakers are 8-ohm, which will cause further loading. You should consider replacing the speakers with 4-ohm and possibly add an amplifier to the system to achieve optimal performance.
Aug 01, 2014 | Pontiac Grand Prix Cars & Trucks
Very low volume output even with the volume turn all the way up. I connected the system to different computers and came up with the same problem. The volume on the computer is also turn all the way up and...
I had the same problem and found the root cause to be the RF speaker connector at the back of the subwoofer. The male and female connectors are OK. It is the 5 male pins inside the connector and the way they connect to the female holes that is the problem. Wiggle the RF speker connector as you move it in and out until you get 100% of audio voilume back. Once you get it back, do not move the connector. Have not found a permanent solution to date beyond this.
Jan 08, 2010 | Dell ADA745 Computer Speakers
Stereo volume goes up itself
Funny huh? Actually, some aftermarket radios like Pioneer have a setting where it senses cabin volume and ups the radio volume itself to overcome cabin noise. I doubt this is your problem and belive the unit is really "mental" and needs repair/replace...
May 07, 2009 | Car Audio & Video
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
Dec 15, 2007 | Philips HTS3440/37 System
Volume really low
sound mute problem.
are you with electronic knowledge to fix this?
i can help.
nuwan.
Jan 11, 2007 | Sony MHC-G100 Shelf System
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Samsung HT-P10 Theater System Logo
19 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
