Question about Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver
Fill coffee container error saeco talea - Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver
dutchman05
  • 487 Answers
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Posted on Apr 16, 2008
SOURCE: Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Posted on Jul 27, 2009
  • 1089 Answers
SOURCE: leeks coffee into grounds container
HI
You have a stripped thumbscrew. Check the top left side of the brew unit. The thumbscrew is the little rod that sticks out of the top of the center part of the brew head. If there is water in the center cavity that's your problem. If you push down on the rod and check your brerw head screen on the other end it is probably pushed out a little. Pry the screen out, and you should see a barrel nut in the middle of the screw stem. Pull the thumbscrew out from the other end.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item about that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Posted on Nov 17, 2009
  • 20 Answers
SOURCE: Saeco Talea Ring Plus
Grinder motor is not working.When the machine do the self test on startup, it senses the grinder motor is in open circuit(error 1).
Have to replace the grinder motor.
Remove the coff beans hopper.then..front spout by pulling the knob off and undo the screws...lift the top cover up from the back to unclick then pull the front part towards you from the center then slide over the spout area. You will see the grinder is covered with rubber cover with 4 screws holding it...remove the screws and then push down the rubber protrution through hole to detach from the grinder.The grinder is yours.
Posted on Dec 23, 2009
  • 81 Answers
SOURCE: Hi, I have a Saeco Talea Giro Plus machine and
Hi Natasja, try pull out the driptray and dreg draw while the machine is on and wait about 10 secs. When the red light start flashing, put the parts back. The red light should dissappear. Good luck.
Posted on Jul 05, 2010
My Saeco Talea Touch machine stopped working this morning after a first cup of coffee. The error code on the screen said Restart to solve the problem (with a wrench key). I restarted the machine but the...
Had the wrench icon problem on a used Talea Touch that I bought.
Don't know how it started with the previous owner.
Solution - cleaned compressed coffee grounds from the grinder discharge. You need to manually spin the motor to clean all grounds from the rotation discharge gate.Also needed to probe and press the electrical connections to the motor. The brush spring and capacitors are press connected.
This solved the problem.
I've owned abnd repaired many Saeco machines. They are poorly designed and over priced.
None the less the majority of their problems can be fixed by simply cleaning the components.
Enjoy
MDR
Sep 08, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Talea Touch - Drip Tray not raising/lowering smoothly
It can be the sensor or the engine that have to be replaced:-(
Best regards
/Mirran
Sep 08, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Logo
140 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
