Question about Casio G-Shock G2600 watch
Stuck in st mode - Casio G-Shock G2600 watch
Cannot set time on 45/7012
Hold the reset button (upper left button) until the seconds start to blink. To go to the hours, push the mode button (lower left button). To set the hour, push the ST/STP button (upper right button) to the desired hour. To go to the minutes, push the mode button again, set the minutes with ST/STP button. To go to the date, push the mode button, set with the ST/STP button. Once done, simply hit the reset button to complete. Hope this helps!
Mar 13, 2011 | Armitron Watches
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
Stuck on 24hr time setting
Hi dale_3fan,
You can change the time and day of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Sep 24, 2010 | Armitron 40/8125BLK Digital Sport Watch
How do you set the time?
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Jan 13, 2010 | Watches
Digital umbro watch purchased 2001.How to change time please. 2 buttons on left. top light, bottom mode. 2 on right, top st/stp, bottom reset.
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Thanks!!
Oct 06, 2009 | Bulova Watch
How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch. "ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The options appear in this order each time you press the "ST/STP" button: minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
Mar 15, 2009 | Watches
Changing the time on my wristwatch
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
Mar 08, 2009 | Armitron Two Tone Sports Watch
Changing the time on an LCD Digital Watch
Malcolm S
Feb 29, 2008 | Watches
Setting the date
If not in the time mode, press mode to get to the time mode.
While in the time mode, press and holdlap/rst for two seconds.
The seconds will begin to blink.
Press st/stop to reset seconds to zero
Press mode and the minutes will begin to blink.
Press st/stop to advance the minutes
Press mode and the hour will begin to blink.
Press st/stop to advance the hour
Press mode and the day and date will appear. The day will blink.
Press st/stop to advance the day.
Press mode and the month will begin to blink.
Press st/stop to month the minutes.
Press lap/rst to return to normal state with you new settings. You can hit lap/rst to return to normal state at any time in the process, for example if you only want to set the minutes, just hit lap/rst after you set the minutes.
Apr 28, 2007 | Timex 1440 Nylon watch
Casio G-Shock G2600 watch Logo
12 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
