Question about Proform XP Weight Loss 620 Treadmill
Stops when i stand on it
I have had it for about 6 yrs now it stops when I stand on it.
"Stand by" red light is on and manually pressing power, menu, etc doesn't work. Do not have a remote. How do I power on the TV?
Hello
You can turn it by pressing the button on TV back bord the a power button just click it and it will turn the TV in
Sep 03, 2017 | Televison & Video
Good Morning, I have a Hunter foor standing,
Hi medoody...
Sounds to me like you need to disassemble,clean and oil your fan.
After 5 yrs of running it probably needs it badly.
Please take time to rate me
Aug 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
GE Externa Tritan XL (7 yrs old): Standing dirty water
Hello, there isnt much that you can do, there could be a number of problems. It could be a slight blockage somewhere from your drainage hoses to your pump. It could also not be spinning properly. If you want to drain the rest of the water out you will need to get your drainage hose and lay it flat on the floor to a drain, this will stop things getting smelly. You just may have to get a repair man in, I hope this helps.
Nov 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Sep 15, 2009 | Microwave Ovens
Shv6803uc bosch dishwasher won't stop beeping at end of cycle, I believe this is about 6 yrs old but I don't have the manual.  thank you
CALL 800 944 2904 THEY WILL WALK YOU THROUGH OTHER WISE OPEN THE DOOR AT END OF CYCLE AND BEEPING WILL STOP
Jul 20, 2009 | Bosch Dishwashers
TV suddenly stopped working - won't switch on from top - won't respond to remote - no standby light - fuse is fine - set is 3 yrs old
The Power Supply is probably causing the problem if you are not getting any response or LED flash or Stand by
Jul 03, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Not turning on
you need to replace the flyback which is flyback 259296 and also capacitor CP150 and CP114. You can get replacement parts at the following link and they include free step by step instructions with pictures so you can easially repair the set yourself. Heres the link.
http://servicemanuals.vstore.ca/
Nov 15, 2008 | RCA D52W23 52" HDTV CRT TV
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hrs9500 stop after 6 sec
Also have te same problem with a S9700.
Switches to stand by after 6 seconds again and again.
Please help!!!
Oct 29, 2007 | JVC HR-S9500 S-VHS VCR
Proform XP Weight Loss 620 Treadmill Logo
52 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
