Question about Dryers
Hoover vhc681b wont start to tumble and is buzzing
3 Suggested Answers
SOURCE: Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Posted on Oct 21, 2009
  • 332 Answers
SOURCE: VHC681B Condenser Tumble Dryer Manual
goto the manufactors web site and download it
Posted on Dec 26, 2010
How is Hoover VHC681B door seal fitted? Does the thin outer flange go into the groove with the square section or is it supposed to overlap the body of the machine?
the wider end fits onto the tub.If you put a long thin screwdriver through the door interlock hole to hold the retaining spring (the stretchy wire type) you will find it will go on easier.
Feb 24, 2015 | Hoover Washing Machines
Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
May 14, 2012 | Hoover VHC391 T-80 Dryer
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
Dec 26, 2010 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
My Hoover TC650 condensor dryer has a fault. When turned on it makes a noise (buzz) but the drum does not revolve. If I turn it by hand and then quickly close the door and press the button it will...
i saw your question and never worked on a hoover dryer so i checked it out go here to see video
https://www.how-to-repair.com/help/hoover-candy-tumble-dryer-drum-not-turning-and-belt-ok-faulty-capacitor/
i have to tell you on all the dryers i've ever worked on they never had a cap in them,only washers,on a dryer that isn't a condenser dryer if you get the dreaded buzzing sound and start it like you did,open the door,hold in the door switch and spin the drum with your other hand while someone else pushes in the start button and it would start it would be the motor,i've seen a condenser dryer and the problem always was with the filter,people that had just bought one didn't know you had to clean out the filter box,never took one apart,i saw that nobody answered you so i hope this video helps you out and i learned that condenser dryers have a cap in them.
Dec 30, 2017 | Hoover Dryers
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Hoover hdv fm tumble dryer
only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Sep 11, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Dryers Logo
27 people viewed this question
Top Dryers Experts
