Question about Philips Magnavox 51MP392H Rear Projection Television
Blue is blurry
Used convergence... Lines green and red up fine, but blue for all menues and on convergence is completely blurry.
Can anyone help me. What is wrong with it and what do I need to do.
Any help would be appreciated.
This is a Magnavox 1995 50" rear projection.
  • Schumi1 Nov 04, 2007
    Thanks. I did this for all of them. The red is crystal clear. The green has just a hair of haze in it, but the blue is clearer yet you still can't read the word "Blue" in the convergence. Anyword in blue is just a haze, but it's brighter than before.
    Thanks for the help.
    Any other suggestions?
Take it apart turn blue lamp until it is clear. A napkin over the green and red lights during this step is very helpful
Posted on Nov 02, 2007
Red,blue,green lines in screen....sound is fine. How can I converge the colors back?
Go to Menu then Setup Look for Convergence, If you do not see Convergence in the menu, then you have a blowed Fuse on the Deflection board.
Dec 23, 2010 | RCA R52WH73 Projection Television
Lines, a little blurry, a little movement
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
You can see some more examples and find a fix using this link on Fixya
Jun 10, 2010 | Hitachi 51F59 51" HDTV Projection...
Mitsubishi WS-65611 Repair kit from no fix.....
I have a few ideas but they all will require some more information from you. I know these sets very well-if you fixed the convergence problem my hat is off to you--it can be a do it yourself job but not the most easy set to do it on.
Let me assume you adjusted the convergence in the customer mode--it does on any of the HD models have to be adjusted in the regular and then the HD modes.
The only other thing here that may be the problem is FOCUS. A simple way to determine this is to remove the back cover--turn the set on and call up the advanced convergence grid---then cover the lens for each tube one at a time--with red and blue lens covered are the lines in sharp focus or look blurry?
Repeat this with only red or blue not covered and see what you think--if one of the tubes is out of focus you will see it there--
There is also a TECH menu for adjusting the convergence-like the customer menu but it saves the adjustments into the set's memory--you will need to hit menu and a four digit code based on the actual model number of the set.
Check to see if focus is or is not your problem-easy to tell--green, red, blue lines will either be sharp or out of focus--if out ask and I will tell you the simple way to adjust that.
If this information has helped you rate this solution as I do this here for free.
Dec 22, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Hitachi 53UWX10BA dynamic convergence works but blue is blurry
I know this set very well---you are saying convergence adjusts ok everywhere? If you understand that the blue is usually de-focused a little----there are only two ways to adjust the focus of each tube-----
1.) Behind the front speaker grill there is an inspection plate---with it removed you will see a small black plastic block with 6 controls on it; it is the MASTER SCREEN/ FOCUS BLOCK
2.) THREE of the controls left to right are Screen controls(red, green and blue) and the other 3 are FOCUS--IT IS ALL black and you need to look close to identify which is focus and which is screen---you are looking for the BLUE focus control(one of the 6)
3.) With the convergence grid on screen cover the RED and GREEN lens in the set and try to adjust the focus of the blue(I presume you know how to put the set into the Convergence mode?
4.) The only other way to adjust the Blue focus is from the back of the set---with the Red and Green lens covered up place a blanket over the top of the set that covers the whole screen--from the back of the set you will note that all three of the black focal lens have a wing nut---with the convergence grid up and only blue lines present(Green and Red lens covered with a cloth) look from behind the set at the grid---loosen the wing nut on the blue lens and slowly slide the lens left or right until the blue has the best focus possible----if it will not adjust with the focal lens or the front focus control you have a circuit problem.
I do this here for free and if this information helps you take a minute and give me a vote here. If you have any questions or need advice reply to this posting here and I will assist you.
Sep 14, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Samsung Rear Projection Problem (not convergence)
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
Jun 24, 2008 | Samsung HCM4216W 42" Rear Projection...
What is your Chassis # ? And convergence problems can be some of the most hard to realign. You may need to replace amps.
Jan 08, 2008 | RCA P52926 52" Rear Projection Television
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
