Toshiba 55vl900a wont turn on
Tv lcd not comming out of standby mode
freetek
  • 5568 Answers
SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.  What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 29, 2008
  • 21 Answers
SOURCE: TV ON STANDBY MODE
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3701AD POWER SUPPLY BOARD MLT386X
Posted on Dec 30, 2008
  • 197 Answers
SOURCE: toshiba 36'' crt tv that goes on standby mode
check for cold solder joints
Posted on Jun 09, 2009
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
Posted on Jun 10, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: Ilo 32 inch LCD wont turn on
power supply bad inside of tv
Posted on Aug 28, 2009
Toshiba LCD LED TV Not working.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 22, 2016 | Toshiba Televison & Video
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
My sony kdl-46v3000 standby light blinks 5 times tv wont turn on
The TV enters standby mode when there is no signal for 30 seconds. https://docs.sony.com/release/KDL46V3000.pdf
I searched standby using Ctrl+F and found this information. It seems you should be able to bring it out of standby using the power button on the remote. You want to make sure there is an input connected and if it is connected to a PC that the PC isn't telling the TV to go into standby.
Try pressing the input button and changing inputs once you press the power button and the Standby is flashing.
If this doesn't work you may need to contact Sony Support.
1-800-222-SONY(7669)
Apr 10, 2014 | Sony Bravia V-Series KDL-46V 46 in. LCD...
Sanyo tv standby mode
Too little details here - need model, chassis, more specific behavior details.
This may help:
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
May 06, 2013 | Sanyo 42 in. LCD TV
Am having the same problems. The TV is on standby (red light on front) but wont turn on from the remote or from the side of the set. This can last 1 or 2 days, then it works fine again for another week,...
There is a problem with the power switch board,there might be short in the IC Unit , you might have to change it. get it serviced by a TV electrician soon before the board gets damaged.
thanks for rating good luck
Feb 08, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
I have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Sep 25, 2009 | Sharp 27N-S100 27" TV
My hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Feb 28, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
My sharp 26"lcd tv stuck in standby,wont turn on
I had a same problem with sharp LC-40LE340E. The service told me to change motherboard but I decided to buy a new LG TV. The sharp TV I left unplugged for a 50 days and after that when I tried again the tv started normally. I was Really surprised. Don't spend money just wait and check again. shkelzen65@gmail.com
Oct 12, 2007 | Sharp LC-65D90U 65 in. LCD Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
