Question about Sony PDW-F355 DV Camcorder
PDW-F355 ERROR CODE 02 F 37 - Sony PDW-F355 DV Camcorder
2 Suggested Answers
  • 368 Answers
SOURCE: SONY PDW-F355 with error code 02-F37
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Dec 01, 2012
Sony camcorder xdcam pdw-700 error codes 91-225
No matter what errors are present you will need the manufacturer to repair it, they do not supply repair info or parts to the public, only approved repair stations.
Feb 22, 2017 | Sony Office Equipment & Supplies
Pdw u1
Re format your computer that will fix it
Apr 25, 2014 | Sony Televison & Video
SONY PDW-F355 error code 02 F 37
There was a firmware update (2.01) to correct this. May 14, 2012
Servo drive function is improved as follows.
The servo drive is now adjusted correctly, and the adjustment no longer results in offset values from characteristic variations in the alignment disc (PFD23A-RS).
Previously, when not adjusted correctly, inserted discs were not recognized, DRV ADJ Err (Error 6F-E00/6F-E80) appeared, and the unit stopped operating.
Apr 15, 2013 | Sony PDW-F355 DV Camcorder
Hi we have a PDW-HD1500 with an error message/code of Error02-FB7. Thanks.
Error code 02-FB7 means "No movement is detected in the ND filter initial operation check of OP (OP1)", meaning the filter that regulates the ammount of light coming out of the laser diode is faulty. It does not say what the problem is, only that there is one.
Swapping the OP (Optical block assembly (the laser thingy on the two rails in the ODD)) for a new one will certainly fix this problem. just make sure you don't touch the lens!
Jan 02, 2013 | Sony PDW-HD1500 XDCAM HD Compact Deck...
Dec 01, 2012 | Sony Cell Phones
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
May 08, 2012 | Sony PDW-U1 XDCAM Drive Unit PDW-U1 USB...
Hi when i put the XDcam DLA 50 GB disc in my Sony PDW 510 XDCam recorde geve code 03 - 354 error. i dont know about dat. do You can help me ? Thank
03-354
03: optical drive two-axis (FCS, TRK)
-354: No signal from disc required for OP focus servo can be detected. Disc is not rotating
I would try another disc and if you get the same error call Sony's service center.
Sep 21, 2011 | Sony PDW-510 Camcorder
Error message 03-354 on Sony PDW-510. What is it?
You may be using a disc that isn't compatible with the camera. This message appears if you put a 50 GB disc in a camera that can only use 23 GB discs. The error will not clear until you put the right disc in.
Apr 11, 2011 | Sony PDW-510 Camcorder
Error 03-454 on pdw1500 deck
What is error03-354 on my Sony XDCAM PDW-F350L?
Thank you. HELP! email: kaltpro@gmail.com
Jan 18, 2011 | Sony PDW-510 Camcorder
Cel daily
Could be a dirty air filter or intake obstruction. Those codes are for oxygen sensors and MAF. Hope that helps a little.
Jul 20, 2008 | 2006 Ferrari F355
Sony PDW-F355 DV Camcorder Logo
89 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
