Question about Xterra Fitness TR6.55 Treadmill
Treadmill is showing an error code of 5....what does that mean?
Brand new, just out of the box.
My F1-3000N WNQ treadmill is stop and is showing E54 error, what does this error code mean?
If you wish to get some details treadmill error codes and calibration ; check the site linked here. http://electro-medical.blogspot.com/
Nov 05, 2016 | Exercise & Fitness
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
Reebok Treadmill error code 5
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
Feb 20, 2014 | Reebok Exercise & Fitness
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
Got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
1) this means a) problem with the speed sensor b) main motor problem c) main motor board faulty. see the block diagram attached.
God bless you
Jun 24, 2012 | Exercise & Fitness
What is error code e4 on vision fitness t9350?
I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
It runs up the speeds and back down but then stops without ever showing 'end'.
When i then take the safety key off and replace it the E4 error code shows again.
The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
Any advice?
Feb 18, 2012 | Exercise & Fitness
What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Jan 18, 2010 | Precor 9.21 Treadmill
Proform 490C showing error code ssytem cehck
The checksum failure is an indication of a bad console on this model. If the machine is brand new then it still has a warranty. Contact the number on the front of your manual they will replace it for free. Good luck, Tim
Nov 09, 2009 | Polar Exercise & Fitness
Tread will not move, shows a L 5 error code
You need a new lower control board. 225.00 from nautilus.
Dec 14, 2008 | Bowflex Treadmill Series 7
Xterra Fitness TR6.55 Treadmill Logo
Top Xterra Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Xterra Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
