Question about DeLonghi EW0507 Oil Filled Radiator Heater
Ran the heater worked fine but went to unplug and the cord was too hot to unplug. What could be wrong that the cord got so hot?
    Problem Solver:
  • 15 Answers
Have an electrician replace the power cord.
Posted on Nov 29, 2014
I have a Bunn Ultra 2 machine it was working fine last week I left it running and when I went and looked at it yesterday it had shut off and would not start up. I unplugged it from the outlet and it...
was it hot? the compressor may be overheated and went into shutdown until it cools. it's safety feature if the fan stops or if the airflow is blocked by too much dust. clean the filter, check the fan, and try again. if it's not hot, it's the transformer that powers the main circuit board.
Apr 14, 2013 | Bunn Margarita Machine Ultra 2 Slush...
1994 ford taurus overheating has no heater cord
check the oil and see if its milky
Apr 09, 2012 | 1994 Ford Taurus
BH 3950 plug overheating
this happens when you have run a heater for a long time on an outlet that is either not giving the heater enough amperage or to much amperage try it in a different room if the problem persists try a different heater.
Nov 05, 2011 | Humidifiers
Electric plug gets hot when pluged in. Is this dangerous to replace plug. i have two one is alright.
Shirley, more than likely, the heater cord's plug is not the problem. Something inside the heater is over heating and causing the plug to over heat. Since it's a molded plug, I don't suspect the cord has been damaged inside the plug, unless someone unplugged it, by pulling on the cord, rather than pulling the plug out. So, just replacing the plug is not a safe option at this time. A small appliance repair shop, can test the heater and tell you what is wrong and if it's worth repairing.
Hope this helped you and thanks for choosing FixYa..
Sep 23, 2011 | Heating & Cooling
I received the Patton Electric Heater model number PUH682 for a Christmas gift. It worked fine for about one week then just about 3 days ago, when I went to unplug it, the plug and cord were just red...
I saw your post and I encourage you to report your problem to The U.S. Consumer Product Safety Commission. I called them to report the problem. The number to the company (Patton) is 763 444 8567. The number to The U.S. Consumer Product Safety Commission is 1-800-638-2772. The U.S. Consumer Product Safety Commission will take your report and if you know others that have this product and they have experienced the same thing encourage them to call and report it. The heater I had melted unto a ultility extention cord and was smoldering. It could have cause serious injury or damages to me and my family.
If this product could have injured you as well. The are a public hazard and need to be recalled.
Jan 04, 2011 | Patton PUH680-U Utility Heater
Cord gets hot where you plug into outlet hot meaning warm to the touch but can hold your hand around cord and is comfortable.Is this dangerous? Could this start a fire?
Not dangerous at all. All heaters create some warmth around where the plug enters the outlet. WARM, not hot, if it's HOT too the touch, then it's a problem. Never use extension cords, and never splice the cord... also don't run the wire under rugs etc... you'll be fine.
Feb 28, 2010 | Honeywell HZ-3220BW Compact Heater
What kind of extension cord to use?
You should use a cord with the ground wire in it. If you're running a heater and the wire is getting hot, it's not whether it should be an indoor or outdoor cord it's the wire size that's the problem.
If you wire is getting hot you need a larger wire size.
Depending on the amps of the heater rule of thumb
15 amps a minimum of 14 gauge with ground
20 amps a minimum of 12 gauge with ground
30 amps a minmum of 10 gauge with ground
If you are using a cord over 15 to 20 feet then you may want to go to a larger wire size.
You will know if the wire size is correct if you let the heater run for a while 20 to 30 minutes and then feel the wire it should just barely feel warm it shouldn't get real warm or hot.
Dec 28, 2009 | Vornado REH1-0001-01 VortexHeat Compact...
Hot water heater does not light
burner and pilot assebly and orifaces need to be cleaned
Sep 16, 2009 | Fasco Bradford White Water Hot Heater...
Electric cord becomes extreamly hot when using a very short time.
the wife is right you have a problem with heater or electric supply to heater dont use it
Mar 12, 2009 | Heating & Cooling
Open Questions:
See all DeLonghi EW0507 Oil Filled Radiator Heater Questions
DeLonghi EW0507 Oil Filled Radiator Heater Logo
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
