Question about Whirlpool Refrigerators
Water in left bottom crisper drawer
Whirlpool Fridge mod# et8wtkxkq0 We have had great service out of this fridge for years, but here lately, the left side crisper drawer keeps filling up with water. It also puts water under the crisper drawers and then eventually leaks on to the floor. I have done everything I know and followed all troubleshooting advice I could find. Can you please help. I am a disabled vet and just can't afford to get a repairman or buy another fridge... Thanks
  • Whirlpool Master
  • 1,830 Answers
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Posted on Jun 11, 2017
zeusfaber
  • 247 Answers
SOURCE: fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Posted on May 16, 2007
bluegreenash
  • 661 Answers
SOURCE: Fridge filling with water
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Posted on Oct 09, 2007
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
  • 89 Answers
SOURCE: water in bottom of fridge and in crisper drawers
the defrost drain in the freezer is clogged with ice.
empty the food from the freezer, and put through a defrost. you might have to help the fridge defrost with a hair dryer. you may also have to remove the rear panel (inside the freezer) or pending on the model to bottom panel of the freezer.. (usually held in by 1/4" hex screws.)
melt all the ice, and be sure that the drain is clear, and it should work.
Posted on May 26, 2009
  • 82 Answers
SOURCE: Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Posted on Jun 19, 2009
O have a GE Fridge Model GFSS6KKxass i am having a issue with water accumilatimg under the both crisper drawers not sure what is causing this?
My GE Fridge did the same and the repair man I called said there is a little drain hose that goes from the top to the bottom of the Fridge at the rear see if that hose is plugged. I unfastened it at the top and blew air through it and the water is no longer a problem.
Jul 19, 2014 | GE Refrigerators
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Water accumalating in the bottom of the fridge.
A common problem. All modern refrigerators have an automatic deicer. The heater kicks in, then MELTS the ice in build up in the freezer for a short period before freezing again. This water drains either in the fridge or out the back to the catch tray. Simply pull out the bottom drawers and clean the clogged drain hold where the water can drain and evaporate in the catch tray as it is designed to.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in bottom of fridge and in crisper drawers
May 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
|Need to identify model to order spare parts
MG,
Check inside the freezer compartment. Pull the drawers out... there's a sticker in there with the model number on it but it's wayyyyy hidden.
SG
May 23, 2009 | Whirlpool Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Frozen Veggies in Crisper Drawers and Water under Drawers
water under the crisper doors is pretty common, all you have to do is raise the front legs of the refrigerator, Refrigerators have a heater in them that keep everything from freezing, if it wasnt for the heater then it would just be a freezer, now alot of these samsungs have 2 evaps, so if you get a warm fridge, its prob. because a sensor is out or the heater is out and there is ice buildup inside the unit preventing either the fan from turning, or just blocking air flow, but for the water, just raise the front legs and there is a drain in the back that it will go into from now on
Jul 29, 2008 | Refrigerators
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
