LAVAMAT 86760 Fault code c9 - Washing Machines
SOURCE: AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Posted on Jul 31, 2008
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
Posted on Sep 25, 2008
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
taran_2005
  • 10515 Answers
SOURCE: What means error code
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 28, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
What means error code "C9" ? AEG Lavamat 74652
C9Motor tacho fault •Check main drive motor •Check tacho magnet •Check tacho coil •Check module
May 27, 2014 | AEG Lavamat 88840 Front Load Washer
I have a AEG oko-lavamat 75520 update. It stopped and the code C9 showes on the display. What does the code mean, and is this something I can fix my selfe?
Hi Mrs Willems from retired Englishman in SW France,
According to my list, AEG Lavamat 8*** Series Onwards C9 stands for 'tacho fault' (monitoring the motor speed) requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 16, 2011 | Washing Machines
My washing machine stops and shows C9...what's wrong??? (it's an aeg oko lavamat caresse) Who can help me?? cheers Jan
AEG Lavamat 'C9' decodes as 'tacho fault' i.e. something wrong with the motor/speed/sensing. Sorry but that looks like an engineer call is required;-0(
If this has clarified the situation and/or assisted you please consider a 4 thumbs up for the rating.
John C
Apr 29, 2011 | Washing Machines
AEG Lavamat 72 620 What does error code C9?
c9 means the electronics is not detecting any drum movement. check the carbon brushes in the motor this is usual culprit.
Aug 29, 2010 | AEG Lavamat 72640 Front Load Washer
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
What means error code "C9" ? AEG Lavamat 76669
Hope i helped you.
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
I need a motherboard for a aeg lavamat l62622
I have an AEG WITH ERROR CODE C9 IT WONT SPIN OR WASH ,COUNTS DOWN THE CYCLE ,FILLS BUT CLOTHES ARE LEFT A STICKY MESS ,MOTOR AND BUSHES ARE FINE ,I HAVE RESET NUMEROUS TIMES BUT STILL GOES TO C9 ANY IDEAS
Feb 26, 2010 | AEG Washing Machines
Jul 04, 2009 | AEG Washing Machines
Washing Machines Logo
Top Washing Machines Experts
