Question about IBM ThinkPad T20 2647 Notebook
Error 0175 bad crc stop post task
sandrew
  • 2961 Answers
SOURCE: stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Posted on Aug 07, 2007
  • 81 Answers
SOURCE: error code 175
If you have access to the internet another way, search the error code by googling it, or going to the IBM website and searching it anf for solutions.
Posted on May 30, 2008
  • 68 Answers
SOURCE: while booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Posted on Oct 07, 2008
Geekman
  • 32281 Answers
SOURCE: error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
Notes:
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
0175
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
Posted on May 16, 2009
  • 199 Answers
SOURCE: ERROR 0175 BAD CRC1 COMMAND STOP POST TASK
the crc is the cyclic redundance check your bios is corrupt. you will need to flash the bios to bring it back the internal bios bottery will need to be removed for 1 min then replace. it should bring it back if not you bios chip has burnt out. i have never replaced a bios chip but you will have to find one to replace it
Posted on Jun 24, 2009
Error 0175: Bad CRC1, stop post task
ERROR
0175: BAD CRC1, STOP POST TASK.
Firstly, this error is generated due to a couple of different reasons. First, there may actually be a problem with the power circuitry and the CRC function is actually doing it's job reporting the error. There are several tests you can perform to tell if this is the case with your system.
Secondly, this bad CRC error can be generated by sudden power loss to the system, especially if the system loses power during boot up or POST process. Both mean that there could be a problem with the motherboard and it needs replacing.
Try the steps below to determine what is wrong.
1) Start the system and watch the status lights in the LCD hinge or near the power button. They should flash once (some models twice) before the system shows a display. If they flash 3 times or more, you have a power problem.
2) Start the system and allow it to reach the CRC "stop post task" error message. Let it sit at this error for several hours. The system should sit at this error for ever or until user intervention occurs.
3) Some things to watch for while the system is sitting at the CRC error and running for several hours would be: Screen going black, System rebooting, System powering off, ect.. ect.. ANY activity by the system is a warning that power problems exist in the system.
4) Try restarting the system several times consecutively, shut the system down by holding the power button for 5 seconds, then restart keeping an eye on the status lights for any additional flickers.
All the above tests should be done with AC power applied and battery installed. Also ALL drives installed.
Regards.
Jan 19, 2011 | IBM ThinkPad T23 2647 Notebook
ERROR 0175: bad crc1, stop post task
0175: bad crc1, stop post task ,ibm t20
Jan 16, 2011 | IBM ThinkPad T20 2647 Notebook
Post problem
If it beeps (which it should) means that some device did not pass post. Find your motherboard online and look up the beep codes. This should help you to discover the problem. I hope this helps!
Jul 15, 2009 | IBM ThinkPad A21m 2628 Notebook
Ibm notbook. how will i solve "bad crc1, stop post task. with an error code 0175?
The POST error code 0175 refers to a CRC (cyclic redundancy check) reading from the EEPROM chip, that data is corrupted, most likely a faulty EEPROM chip. This is a motherboard problem and cannot be fixed except by a motherboard replacement. This is an old laptop and would not be worth fixing, I suggest you put your money towards a new laptop.
You can remove the hard drive and put it into an USB hard drive adapter case and use it as an external USB hard drive.
Jul 12, 2009 | IBM ThinkPad A21e 2655 Notebook
Jun 24, 2009 | IBM ThinkPad T60 Notebook
CANNOT START BOOT GIVING EROR CODE 0175
This error seems to represent motherboard problems and most likely requires new motherboard. Unfortunately most laptops that are a few years old arent worth fixing, unless you can do it yourself. Try to find a used model same as yours for parts.
Char S.
May 21, 2009 | IBM ThinkPad T20 2647 Notebook
Error 0175 bad crc1
Notes:
Error code
Symptom or error
0175
System board
May 16, 2009 | IBM ThinkPad T20 2647 Notebook
IBM Laptop A22e Display an error 0175
The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
Stop POST task, bad CRC1 error 0175
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
IBM ThinkPad T20 2647 Notebook Logo
35 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
