Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Cual es el firmaware
Konjca minolta bizhub 350
  • Konica Minolta Master
  • 6,161 Answers
Firmware is only available to Konica Minolta Dealerships and KMBS through a secure web site so it will require a service tech Konica Minolta likes to protect there copier software
Posted on Jan 16, 2016
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 214 Answers
SOURCE: Konica Minolta bizhub 350 Error c0500
did you do a trouble reset ?
Posted on May 11, 2008
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
pineworks
  • 4041 Answers
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Cual es el codigo de control de la universal general electric 24991, para un tv TECNOMASTER
Cuales es el c?digo de mi control general el?ctrico ge24991 para sony Brav?a de 42
Mar 30, 2015 | General Electric Televison & Video
ERROR C1183
Code is on the Copier, but I digress. Did someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the top tray has to just touch them.
Mar 13, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
EL ALTERNADOR ES NUEVO LA BATERIA TANBIEN PERO NO CARGA QUISIERA SAVER CUAL ES EL RILEY DE EL ALTERNADOR
El relay de tu auto esta situado en la caja negra de fusibles la lado de la bateria enfrente, es una azul en la esquina superior. Es el mismo que yo andaba buscando suerte.
Jan 07, 2013 | 2001 Toyota Echo
Cambie revelador a una minolta di 3510 hice todo el procedimiento de rutina y le di F8 y en la mitad del proceso dice que hay un error y saca el f33 salgo del modo de servicio y apago la fotocopiadora y la...
. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Sep 23, 2011 | Minolta DI2510 Black and White Copier
Quiero remplazar el fusible del estereo pero no se cual es y no tengo el manual para ver el diagrama, me puedes decir cual es
Revisa estos diagramas...
Si es de tu interes, aqui puedes revisar el 1994 Chevrolet 1500- Owners Manual (pagina 345 y siguientes).
Suerte (recuerda calficar esta ayuda).
May 18, 2010 | 1994 Chevrolet C1500
Desbloqueo del codigo m2 en konica minolta bizhub 163
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
Cual es el alcanse de los radios 1061
El alcance de los radios dependera de lo que halla de por medio, si el fabricante te da un estimado, esto es unicamente en condiciones muy ideales que NUNCA las lograras, por lo que si logras comunicarte a 1 Km o menos en la ciudad, sientete satisfecho, estos radio son un jugete, si necesitas comunicacion a distancias mayores deberas de invertir en un radio profesional o con servicio de repetidora
Jan 22, 2010 | BellSouth 1061 (14 Channels) 2-Way Radio
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
32 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
