Question about Elna Sewing Machines
No foot switch for Elna Su (1972-78?)-can I use the foot petal from an Elna Zigzag that I have?
  • Elna Master
  • 1,133 Answers
I'm asuming you have the integrated foot controller and power lead in one, yes these are both Swiss Tavaro made machines and should have the same plug shape so should be interchangeable. Also the bobbins should be identical, seven holes on top and dished. And the feet should be the same too.
Posted on Jul 27, 2017
  • 11 Answers
SOURCE: Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Posted on Oct 28, 2008
SOURCE: Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Posted on Nov 13, 2008
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Posted on Apr 09, 2009
  • 47 Answers
SOURCE: I need a manual for an Elna SU
Visit www.ifixmachine .com
Posted on Jul 24, 2009
Tally Girl
  • 1133 Answers
SOURCE: What make of walking foot
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
Posted on Jun 25, 2011
I need an Air foot control # 436310-20 for my Elna Stella TSP air electronic. How and where I can get this part?
I'd suggest www.sewingpartsonline.com if you are in USA.
https://www.sewingpartsonline.com/air-foot-control-elna-436410-20.aspx
Or you could try the Elna Guru, White Sewing Center www.whitesewingcenter.com, he's the specialist supplier for all things Swiss Elna.
The air control foot is the same for all the Elna Air Electronics, whether Stella, SU, TSP, TX etc.
Mar 20, 2017 | Elna Sewing Machines
Did Elna Carina SU 66 originally come with a straight stitch foot and throat plate?
No, the Carina came with a standard zig zag plate and 5 feet I think from memory, the teflon coated foot , the embroidery foot, buttonhole foot, zipper foot and darning foot.
Nov 16, 2016 | Elna Sewing Machines
How do i fix a n elna su that will not stop after releasing the foot pedal
I'm guessing this is an Elna air electronic SU? If yes, then the problem is with the diagram inside the right side of the machine where your air control foot pedal tube feeds in. I havent' done this repair myself, I took mine to my favourite sewing machine technician. But if you are technically able, try joining the Yahoo Group called Elna Heirlooms, and then go through the threads there, there's been discussion on this repair before.
Dec 21, 2014 | Elna Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
Zigzag feature is not working
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jan 09, 2014 | Elna Sewing Machines
I had a zigzag problem with Elna SU Electronic Air, which I fixed with your solution, but some of the unfreeze liquid had gone down the bobbin winder hole and now the outer wheel on the right side wil
is the belt slipping now? You'll probably need to take off the top cover and see if you can clean up the spilt lubricant off the bobbin winder mechanisim and the drive belt on the right of this. The bobbin winder is friction driven, a rubber ring around a plastic barrel and when you click this over to the right the rubber ring drives off the main drive part of the machine.
removing the top panel is a bit tricky because you've got the handle there too, two screws unscrew it, then you need to manouvere the cover upwards and left to get it out of the bobbin feed part then tip it to the back of the machine to give you a view of the inners. You might want to subscribe to the Yahoo group called "Elna Heirlooms" as there's probably a prior thread on this there, lots of Swiss Elna owners who service their own machines, very useful place to visit.
May 15, 2012 | Elna Sewing Machines
Can a genic foot pedal be used on an Elna Super?
Take a look at the side plate on your Elna and look for a two digit code, this is the model number.
I'm assuming that you are in the USA on 110 Voltage. If so visit this website,
http://www.sewingpartsonline.com/elna-sewing-machine-parts-model-list.aspx and choose your model. They sell replacement foot pedals, just check the profile of the plug that goes into your machine.
The other option is contact the Elna guru, www.whitesewingcenter.com, he stocks a wide range of swiss Elna parts and may have the original foot control second hand.
If you are on 240 voltage then you'll need to source it from a country that has the same voltage like UK, Australia or NZ.
Lastly, you may wish to join the Yahoo group called "ELna Heirlooms" this user group of Elna owners is really helpful and shares lots of their love and knowledge for these beautifully made Swiss machines. Many of them have even earlier models than yours such as the Green Grasshopper, the first Elna machine.
Dec 19, 2011 | Elna 2007 Mechanical Sewing Machine
What make of walking foot would fit my Elna su air electronic sewing machine, thankyou
Jun 25, 2011 | Elna 2007 Mechanical Sewing Machine
I purchased a used Elna su type 62cr209707. I need an instruction manual, where do i find one?
The Star Series SU is a lovely machine,
you can purchase a manual from here - well worth spending the dollars to find out how it works, especially the buttonhole which isn't like modern 4 step ones. You may also find that the foot control has a switch to give you slow speed vs normal speed sewing.
http://www.tradebit.com/filedetail.php/91117786-elna-sp-st-su-sewing-machine-manual
If you are in the USA you could also visit www.whitesewingcenter.com, they have lots of Swiss Elna goodies for sale and are very knowledgable on these machines.
You might also want to track down a newer Swiss made Elna pressure foot holder with the clip on feet, rather than using the full feet with your machine. They are interchangeable. Have you got the black discs to go with your SU too? there is a large range so you can sometimes track down some more to add to your collection.
There is also a newer black pressure foot screw which is a combined thread snip, its a bit bigger in diameter to the black thumb screw on your machine now and you can use it to cut and hold the threads at the end of each seam, very cute.
Always give this machine a good clean and oil before using it, there should be a red dot in the middle of the bobbin holder, oil here regularly and any other points that the manual shows with good quality sewing machine oil, it takes 130/705H standard sewing machine needles, put in a new needle for each project to get great stitching results.
Enjoy your SU!
Apr 15, 2011 | Elna 3210 Mechanical Sewing Machine
Oct 27, 2008 | Elna 1010
Sewing Machines Logo
35 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
