Question about Galaxy Radios DX 2547
Frequency counter keeps moving no tx - Galaxy Radios DX 2547
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Bad solder joint somewhere in the counter circuit .
Posted on Jan 03, 2015
2 Suggested Answers
SOURCE: frequency counter keeps going off frequency
i was told that i have a couple of chips going bad
Posted on May 30, 2008
Usb audio
need to put it on an oscillascope and frequency counter and have it aligned. even taking to a shop should be less than $45 to have it fully done.
Mar 21, 2014 | Magnum Radio Communications
Uniden grant cb radio
You can't You need a spectrum analyzer to set the frequency correctly. This is not something you can do by ear. When you go poking around inside with a screw driver, you can mess up the entire radio.One adjustment will affect other adjustments. That's why there are radio repair shops. Just take it to one.
Jan 23, 2014 | Radio Communications
Try reading from uv5r radio comes up fail to connect to tranceiver
Dear sir,
is both radis are same model , if not do you have frequency counter , these radios already have frequency counters ..pls keep same frequency & disable any privacy code on sets
Jan 07, 2014 | Dual Baofeng Uv-5r Band Uhf400-480mhz...
My hr2600 shows error 3 when it is keyed up and does not transmit
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
*If your radio displays error 3 or 4, don't keep trying to transmit on this frequency. The cause of the problem could be low power supply voltage to the radio or the radio's VCO loop needs adjustment. Refer to a qualified technician for service. Contact the installer of the chip first. If, however, you installed the chip yourself, contact a qualified technician for service.
Sep 24, 2013 | Magnum DeltaForce CB Radio
My connex cx3300hp wont transmit
You need external watt meter& SWR meter..Change antenna..Is the radio meter keying 3/4 way up to 4 watts?(if not then its not Tx'ng)It could be 10.240 mhz crystal or IF pots(need Frequency counter) Or take it to professional Cb repairmen...
Mar 12, 2013 | Radio Communications
Cobra 25 wx st FC 347 wiring
Just about all fc 347 come with instructions on how to wire it to the radio.
Jun 23, 2012 | Cobra 25 Wx St Sound Tracker Cb Radio W/...
My uniden pro510xl transmitts slightly off frequency. Is there an adjustment for this?
Yes, you need a frequency counter to get IFfreq back were it needs to be. google cb shops in temple, tx
Aug 07, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
How to measure frequency with the mastech ms6100 frequency counter?
Simplest explanation is to connect signal to BNC and select frequency measurement (you may need to play around with it a bit) but it's like any other frequency counter - never used this model but if you know what the frequency you excpect then playn around until you get it
Jun 02, 2010 | Mastech Multi-functional bench Frenquency...
No TX
go to a w/shop, you need to have a watt meter to test RF power out.
a frequency counter
RF generator
you can manage at home
Apr 14, 2009 | Radio Communications
Galaxy Radios DX 2547 Logo
63 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
