Question about Vizio VU42L 42 in. LCD TV
Half screen went black but now I have full screen could it be caused by overheating?
Half the screen is black
The white dots are most likely to be failed pixels in the LCD screen. When the picture elements fail, they switch to clear and what you see as white is the backlighting.
The overheating issue in laptops is generally caused by dust and fluff blocking the cooling fins and ducts or a failed cooling fan, but it could also be caused by a hung process which runs the CPU at a high processing speed. Press control (CTRL) ALT and DEL and look at the task manager and see if you can see any processes that are running constantly near or at 100% to eliminate this being the problem.
The failing display is unlikely to be related to the overheating issue.
Mar 17, 2015 | Microsoft Surface RT
My samsung tv overheated and half if it went black
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Nov 16, 2014 | Televison & Video
My TV set went black on the upper half of the screen. Is there a means of getting full screen back without taking it to a repair shop?
that could be cause of loose or broken solder on the vertical circuit esp on vertical output ic.. you can easily fix that resoldering the loose and broken solder esp on the vertical putput ic.. thanks
Oct 11, 2014 | Televison & Video
My lg chocolate touch's screen went half black
your screen has broken and LCD also has broken that's why your half screen is working and half is black. you have to change your screen and then use your phone again like before
May 17, 2017 | LG Cell Phones
Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
Jul 23, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Black screen
It may be repairable, but you will spend less money to replace it.
You did not mention if this is a CRT or a LCD monitor.
If it is a CRT the Rasters and flyback are faulty causing dead areas on the screen.
If it is a LCD then you are having pixels dying, and it will not last too much longer.
You may want to try it on another computer just to verify that it is not your video card.
May 20, 2009 | Computers & Internet
Screen went half black then full black
Sounds like a common voltage adjustment with samsung plasmas,I would call a service center these are things if you dont have experience you shouldnt attempt yourself
Apr 26, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Black out screen
I had the same problem once with my RCA television. It only happened on certain channels and didn't happen during commercial breaks. If I adjusted the volume on the tv the box went away, but came back shortly after. The problem ended up being some malfunction in the closed captioning. I turned it all off and changed the CC settings and never had the problem again.
Oct 05, 2007 | Westinghouse W33001 30 in. HD-Ready LCD...
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Vizio VU42L 42 in. LCD TV Logo
22 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
