Question about Saws
Since yesterday, I can't make a straight cut with the ceramic tile saw Ryobi WS721. What can I do?
Before, it was ok and since yesterday i can't make a straight cut anymore.
  • 29 Answers
SOURCE: Tile Saw Troubleshooting
if your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
  • 32 Answers
SOURCE: how do you square the rigid tile saw to cut
take a framing square and set it aginst the back stop.
then loosen the screws that hole the saws arm to the base.
now set the square aginst the blade and adjust untill it is even,in the front and the back.once you have acheved this tighted the screws on the arm to hold .
Posted on Nov 06, 2009
woobie dog
  • 1273 Answers
SOURCE: I have a small ceramic tile saw. I have
Look for a button that you can press to lock the shaft in position. When you depress the button, you may still have to revolve the blade and shaft until the lock engages the shaft. Then unscrew the bolt from the shaft. Some others have an Allen wrench well in the end of the shaft, and you can insert the allen wrench to hold the shaft while operatiln the wrench to loosen the blade. Some others have a slot in the shaft end for inserting a slotted standard screwdriver for holding the shaft while the wrench is used to loosen the blade.
One of these methods will be available to you!
Best regards,
--W/D--
Posted on Nov 10, 2009
  • 8 Answers
SOURCE: tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Posted on Jul 22, 2010
SOURCE: how do I take the cutting blade off a Mastercraft
you have to stop the blade turning. Grip it with some locking pliers but it might damage the blade. Or jam it with a piece of wood/ stone and undo the nut.
Posted on Nov 24, 2010
Wet saw is not cutting square, blade is new but once it hits the tile is shimmies.
Make sure you have the correct blade. There are different blades for different tile. ie ceramic blade for ceramic tile.
Dec 31, 2016 | Blade Saws
TILE SAW WON'T SPRAY, PUMP AN MOTOR RUN CHECK FOR DEBRI HOW DO I CLEAN TUBING TO SPRAYER I THINK IT IS CLOGGED
Make sure pump is submerged i water
Remove tubing from pump discharge and see if pump is pumping water/ If so your tubing is clogged between pump and saw. Remove tubing and rinse out with hose.
Nov 28, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Ryobi WS721 wet tile saw blade wont turn on start up
I just got one of these and the same thing happened, arbor spun slow and hummed. I fixed the problem by removing the motor mounting bolts I wiggled the motor and the arbor spun like a champ. When I reinstalled the bolts I checked the motor after each bolt. What I discovered was the bolts where the cause of the binding so I relieved the pressure by loosening the bolts a quarter turn each. Saw now works perfect. Design flaw!
Aug 20, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Our on off switch insert is not here, so the saw will not turn on, any way to fix?
You can order the switch key alone, Ryobi part number 080009019088, or the whole switch assembly, Ryobi part number 080009019710, from aftermarket sites like www.ereplacementparts.com or you can go to the Ryobi website, www.ryobitools.com, and find a local or nearby service center that either has the parts or can get them for you.
Jul 03, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
How do i find owners manual
Try here http://services-uk.ryobitools.net/accueil.asp
Jun 24, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Saw will not cut straight and destroys blades 250
I had the same problem. If you are cutting porcelain tile, it will not cut straight. The motor isn't fast enough.
These saws are made for stone cutting.
Jun 07, 2010 | Imer Tile Saw Combi 200va Portable Tile...
Ryobi WS720S wet tile saw. Will not spray
Check the pump operation and pump intake screen for plugging. Make sure the water reservoir is not full of cutting debris.
Jan 24, 2010 | Saws
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
