Question about Klockit AcuRite 13230 My Backyard Weather Forecaster
Red light stays on on the outdoor sensor - Klockit AcuRite 13230 My Backyard Weather Forecaster
LED light installed but does not stay on full powered while using dusk to dawn. how to keep LED Par38 on full power all the time
The darker it gets, the brighter the lamp gets. If it's not getting bright enough at sunset or dawn, simply reduce the amount of light getting to the sensor.
Take a piece of black electrical tape, cut a hole in it, maybe 3/4 the size of the sensor opening, and place it over the opening. If that's too much effect, remove the tape, make the hole a little better, and re-apply it. If it's not enough, use a new piece of tape with a smaller hole.
My neighbor did this, over 30 years ago, after telling his kids they could play outdoors until the yard lamp came on.
Sep 07, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
My motion outdoor light is not turning off.
there can a few reasons for this happening
(1) something is moving within its range , this can be a bush or tree branch
(2) range /sensativity set too high use proper adjustments
(3) some models have a constant on mode that happens when you cycle power too light, turn pwr off and leave off for 15 min then turn back on
(4) lighting , the flashes of intense light drive these things crazy , if a strike comes close , sensor will become perm blinded and stay on
(5) light is defective
Feb 26, 2015 | OUTDOOR Home Security
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Lithonia photocell light stays on during the day
1) Buy twist-lock photo control:
http://www.intermatic.com/en/Products/Sensors/PhotoControls.aspx
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Dtools&field-keywords=twist+lock+photo+control
2) Spray bit of WD40 on twist-lock blades before installing new photo eye, and then rotate back and forth a bit to make sure there is electrical contact.
Test by placing black tape over photo eye.
Feb 14, 2013 | Hardware & Accessories
I need to reset my outdoor lighting == motion detector lighting after a bulb blew. The light just stays on -- no dimming. Is there a catch to how to reset the lighting/
hold down the reset button and stay behind the sensor. Mine does this exact thing in lightning storms it may take a few tries. Good Luck
Nov 09, 2010 | Garden
Outdoor sensor won't work
Hi, Remove the cover and check for power. If you have power,replace it.No power, look for a tripped breaker. Good Luck,
Shastalaker7
Nov 14, 2009 | Heath Zenith SL-6106-IV Motion Sensing...
Lights stay on
manually turn the dial pass the red pointer. that shoudl shut-off the light.
if not, you have a defective timer.
if it does. follow the instruction set the gree pointer for the time to turn-on and set the red pointer to the time off.
turn the dial one or more revolution till the arrow head in the center align with the time of day in the center windows.
Dec 30, 2008 | Intermatic & Indoor/Outdoor Rain Tight...
Heat/ac pump
- If it is a high wall unit yep under charge refrigerant is one of the cause.
- Out of range thermistor is also can also be the cause of tripping outdoor unit with matching blinking light same as low refrigerant.
- Dirty indoor and outdoor can also be the cause
HOW TO CHECK IF YOUR UNIT IS OUT OF FREON
- If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
Jan 08, 2008 | Heating & Cooling
Klockit AcuRite 13230 My Backyard Weather Forecaster Logo
Top Klockit Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Klockit Measuring Tool and Sensor Expert? Answer questions, earn points and help others
