Error 1 Gorenje w7643l. At the end of the program appears an error code instead of end. The error code is ERR 01. What this means?
3 Suggested Answers
jonniewalker
  • 1029 Answers
SOURCE: HELP WAT DOES F-01 MEAN ON MY HOTPOINT ULTIMATE SUPER SILENT WF86
F01 means there is a motor triac has short circuit. areas to check are the motor, connections and module. BE VERY AWARE THAT THIS MOTOR IS A 3 PHASE ONE AND THAT YOU SHOULD UNPLUG THE MACHINE FROM THE MAIN POWER SUPPLY AT LEAST 5 MINUTES BEFOR WORKING ON IT BECAUSE THE HEAT SINK ON THE MODULE HOLDS A LIVE CURENT FOR ABOUT THIS LONG EVEN AFTER DISCONECTION
Posted on Mar 17, 2009
SOURCE: error code 4 Gorenje 63160
First of all:
go to this link and print out the documents. This is a service manual for self testing the washer. http://dc342.4shared.com/doc/FM0C3Sem/preview.html (SPAM FREE)
Run the self test
If the machine self test give you these errors:
Sensor NO
Washing Error
There is probably a problem with the washing sensor wire connection in the bottom of the machine.
Do this:
- Unplug the power
- Turn the machine 180 degrees so you get access to the rear service lid.
- Unscrew the screws on the lid.
- In the left hand bottom in the rear you wil see the water pump. This has two connectors with two blue wires on each connection. One is connected to the bottom of a white connection box on the bottom of the water pump. The other one goes over the top to a plastic joint connector. In my case this one was cut of for some reason.
- Uncut the strip that holds the blue wires in place on the water hose. This will make it easier to work with.
- Unplug the two blue connector plugs. Mark somehow or make sure you remember where both of them go.
-Open the connector on top where the blue wires goes inside the connector plug.
- Check if the cables are intact and in place in the plug. If you are unsure, take out the wires cut of 10mm and strip about 6mm making the copper appear.
- Mount the wires in the holding clamps.
- Connect wires back
- Run self test again
- If ok. Connect the back service lid again.
Posted on Nov 01, 2011
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
Bush washing machine error code 8888 what does this mean
Error code Err 08 The start/pause light, program ready light and program end light blink. The motor has failed. Shut down your machine and unplug. Turn off the tap and contact the nearest authorized service agent immediately. http://electronicshelponline.blogspot.com/
Jul 14, 2016 | Washing Machines
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
Error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
Aug 13, 2009 | Sharp MX-2300N Color Copier
Want to workaround Shrinker.err to be able to download programs. Can it be disabled in any way?
I found that "shrinker.err" is an error
that you get if the product PowerZip 4.50
is installed and fails to start. PowerZip is a Windows utility, a compression tool.
The shrinker.err error is corrected in the PowerZip 5.2 release, the newest version
and that should fix your problem.
This program has nothing to do with any virus.
Hope this helps, Please leave rating...
May 02, 2009 | Computers & Internet
Err 01 during slow shutter speed shooting
I having a similar problem and send back to the Canon service centre for repair. Subsequently, it was confirmed that the aperture diaphragm is faulty and need to be replaced.
Dec 02, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Nov 18, 2008 | 1997 Saturn SL
Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
May 27, 2007 | KitchenAid KESC307 Electric Kitchen Range
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
