Question about Lexmark X3470 All-In-One InkJet Printer
COVER OPEN I just replaced the ink cartridge on my lexmark x3470. The screen displays "cover open". I have opened and closed the cover a few times to try to fix this problem. I have unpluged the power pack and waited for about 15 seconds. It still does the same thing.
  • 6 more comments
  • atoy Nov 06, 2007
    I have the same problem like Jasonishere's COVER OPEN
  • lieudance Nov 07, 2007
    I have the same problem after replacing the cartridge, I found a clip that came off inside, but i have no idea where to put it.
  • vhin Nov 15, 2007
    what does the lever look like?/ can't find it
  • vhin Nov 15, 2007
    what does the lever look like?? can't find it!!
  • kgl101 Nov 20, 2007
    How do i fix this proble i opend the cover and then closed it but it reads "Cover Open" Help me plz???!!!!!
  • printel Dec 10, 2007
    pluged up and still does the same thing
  • Anonymous Dec 12, 2007
    JUST AFTER I REPLACED THE INK CARTRIDGE THE COVER OPEN IS BEING DISPLAYED. THE PRINTER WILL NOT DO ANYTHING I HAVE UNPLUGGED IT , RESET THE SURGE PROTECTOR, DISCONNECTED THE POWER SOURCE . I LEFT IT OFF FOR A WEEK I AM STILL HAVING THE SAME PROBLEM
  • Anonymous Jun 11, 2008
There is a plastic lever in the back of the scanner where it comes into contact with a part made to push the lever when closed to work the switch. It is a poor design. The lever fits over the small micro-switch very loosly and the tabs wear out really quick. Lexmark will not send another lever. They state buy another printer. If you are real careful, you can put the lever back on the switch and hold it in place while you close the lid.
Posted on Nov 11, 2007
Thanks for the posts and pic that helped me solve this problem :)
Posted on Dec 04, 2007
I have the same problem.. i have tryed everything and it still is saying Cover open
Posted on Jun 07, 2008
I changed the ink cartridge and now the printer screen reads "cover open"
Sometiems you have to close the covers firmly to get the sensor to recognize that it is actually shut
Jun 16, 2010 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
Nov 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470
Try looking around the edges of the cover or in the hinge area for a switch that may be stuck. Most covers have a switch to indicate that the cover is open, the cover may not be seated properly or the switch may be stuck in the open position.
Aug 30, 2009 | Lexmark X3470 All-In-One InkJet Printer
Says cover open but its not
Open the cover, remove the ink cartridges, reinstert them, close the cover, and power it back on.
Apr 21, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
Apr 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
Series 3400 printer
If your printer still in warranty please replace the printer or This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located..
Good luck....
Oct 30, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover open message error
HI this will help you, I have located the link and this is going to give you all the info that you need.
Please do not forget to rate our chat session ok
www.fixyourownprinter.com/forums/printer/46998
Thank You
Jayson
Sep 21, 2008 | Lexmark X3470 All-In-One InkJet Printer
LEXMARK 3470 COVER OPEN
there is a switch actuator on these cover try to see if you can find any piece of tab that actuate these switches, unless the cover is really closed ensure that it is fully flat
cheers
Sep 17, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover open
see your printer cover for broken.
Mar 18, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
1,015 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
