Question about Thermador Dishwashers
Light on floor not working
Cant turn on floor light
How do i fix my Chevy Cobalt. Floor shifter stays stuck in park postion. I am pressing brake pedal and pushing the shifter button.
have a helper. tell him to press brake pedal. you come to back of vehicle and see if the brake lights work when helper press the pedal. if lights don't work the tail light fuse has blown. so you cant take from park. and on some brands if horn fuse blown you cant take from park.
Jan 23, 2014 | Cars & Trucks
Cant switch between defrost panel or floor heat stuck in defrost
sounds like maybee a blend door issue or a vaccuum lek
Nov 30, 2011 | 2001 Ford Taurus
Can you advise which setting should be used on different floors, ie hard floors and carpets, theres 2 different settings and I don't know which setting should be used on the different floors
Turn the machine on and look at the bottom. Turn to the two settings. The setting that stops the platten wheel from moving is for hard wood floors. If you cant tell, then setting 1 is most likely for carpets and 2 is for hard wood floors. Your machine is primarily a carpet vacuum cleaner, so 1 should be for carpets.
Feb 03, 2011 | Hoover Vacuums
Cant calibrate tony hawk shred board to my wii. I've tried everything
At last! My Son's Tony Hawk Shred board was one more try from being thown down the garden, as i have been trying since Christmas day, & finally there it was a board i could use. I've followed all bits of advice in a number of differant ways --- here's what worked for me, Turn off at the wall Sky TV, Turn off all lights (only tv turned on), put my crutches in another room (because large metal objects interfere with soft ware), Remove dog from room, Put senser bar on floor, Turn Wii console side on so that Dongle faced away from tv (aiming into centre of room), Place Shred board on floor facing tv/senser at about three feet away. Start process of game set up untill you get to choose a profile, Select profile, press & hold for 5 secs start button on board untill the four blue lights start to flash at a rate of about one flash per sec, then hold on same button untill blue lights flash quickly, then press & hold Dongle button untill Dongle light stays on, with in 2 secs game calibartion instructions start, BEWARE Tony Hawks responce when process starts is as annoying as not being able to get board started. Good luck when up & running it is one Awesome game!
Jan 01, 2011 | Activision Tony Hawk Ride for Nintendo Wii
Hwere is the switch for courtesy lights on floor?
The older cars have a dimmer switch built into the headlight switch panel that turns on and off the interior lights and the dash lights , in some cases it is the pull headlight switch light that one can turn up and down for bright and dim to off position.'There may also be a single thumb turn or twist turn light switch that controls the interior lights located on or around the headlight panel switch.
Jun 06, 2010 | 1996 Oldsmobile Cutlass Ciera
Turn off service engine lite
You cant "turn it off" until the problem is fixed. If you are talking about the Service Engine Soon light. If its the OIL CHANGE light, then turn the key on and depress the gas pedal to the floor, 3 times. that should reset it.
Dec 16, 2009 | 2002 Chevrolet Monte Carlo
I cant synchronise my board with the wii box
Make sure you are trying to sync it when the Wii Fit game asks you to. It will say "place you wii fit board on the floor and turn it on" or something like that. and then when it asks you, turn it on, and it should sync.
otherwise, try it on another wii if you can... if it works on another wii then its your wii.. if it doesnt work on another wii then it is you Wii Fit Board.
Sep 15, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Dishwashers Logo
21 people viewed this question
Top Thermador Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
DROPNDEAL
DROPNDEAL
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
