Question about Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles,
Maytag washer is overflowing in the detergent and softener dispenser
This problem happens for a short period but leaks water on the floor
  • 209 Answers
SOURCE: Our Washer is overflowing through the dispenser drawer
water out of the soap drawer could be a multitude of things, start with removing the drawer and checking for blockage in the pipe from the drawer to the drum, next try turning down the water pressure a little sometimes that can help, or has the machine filled up totally till it overflows, that is a blocked pressure switch pipe, start with looking for the blockage first, work with safety unplug if removing lid etc. rate me if i have helped, thank you
Posted on Sep 16, 2007
SOURCE: Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Posted on Aug 17, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
  • 8 Answers
SOURCE: Maytag MAH 3 Neptune Washer doesn not dispense the fabric softener
my solution was to remove the bleach and softener dispenser inlet all together, and manuall add such things if I need them. Maytag never managed to fix the problem even tho they replaced the parts in that area...
Posted on Oct 23, 2008
SOURCE: MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Posted on Dec 08, 2009
Maytag 5000 series washer leaking.Removed front access panel ,saw water is trickling from dispenser tray area. Pulled dispenser drawer,cleaned/inspected with nothing really standing out as a problem.
Verify that that the hoses from the dispenser tray to the tub are not clogged. Detergents and fabric softeners can build up inside the hoses and cause partial or complete clogs that will cause the dispenser trays to overflow and thus leak. This is a common problem.
Oct 04, 2015 | GE Washing Machines
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG front load Washer MAF1300AAW Water is coming out of detergent dispenser and flooding my laundry. I have tried both powdwr and liquid detergent, the same happens???
ck for blockage on inside of tub where water enters any kind of blockage there (lumpy undisolved dry detergent ,socks etc) can cause blockage and water to back up into dispenser and overflow
Jul 31, 2008 | Maytag Washing Machines
Washer Leaks from Detergent Compartment
Two things might be wrong with this unit.  One problem is there is a blockage inside the hose that sends water into drum.  Make sure that's clear.  The other problem is the dispenser assembly may have a leaking problem and will spray water at an angle that will cause it to leak through the dispenser drawer.  My recommendation is to have the dispenser assembly inspected and possibly replaced.
Apr 24, 2008 | LG WM-2277HW Front Load Washer
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles, Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
