Question about Villeroy & Boch Home
Villeroy & Boch toilets 1995 catalouge - Villeroy & Boch Home
olddewsons
  • 38 Answers
SOURCE: Villeroy Boch subway toilet cistern filling up to much
On this model am not sure if it come apart. But if you have a air compressure try and blow though it. when you have it off toilet. sounds like its dirt caught in it.
hope this helped. :)
Posted on Jul 07, 2009
miket756
  • 2702 Answers
SOURCE: We have a v illeroy and bch cistern that cracked
yes i can,,,he done the scews up to tight that hold then down and the move ment in them is cracking the screw holes out, undo the screws a little that hold them down and maybe put in some rubber washers as well,,,you only sit on them, its not a jig your doing
so they realy dont need to be done down tight only just to hold them thats all,
Posted on Jan 12, 2010
  • 102 Answers
SOURCE: My Villeroy and boch toilet's water level inside
V & B toll free number was 877-505-5350. I hane only worked on one in 25 years and they were very helpful. Hope this gets you in the right direction.
Posted on May 26, 2010
  • 102 Answers
SOURCE: villeroy & boch flush mechenism needs to be replaced
V&B US phone number is or used to be 877-505-5350 they should be able to help.
  • 268 Answers
SOURCE: Villeroy & Boch Sunberry close
Your chain is probably metal that snags under the flap (verify by taking top off tank and looking) and you should switch to a plastic chain.
Easy just replace the flap that stops the water after handle is down and toilet flushes and also replace the chain that connects from handle to rubber flap. New chain should be plastic one so it can be reattached and problem is fixed. Should cost less then 5 bucks from Home Depot or Lowes. They can happily step you through the process. I should take about 2 minutes to install ...if that.
Remember to remove excess links of plastic chain with a pair of scissors. Its doesn't require a rocket scientist.
Posted on Oct 07, 2010
Knob of coffee pot knocked off, Villeroy and boch switch 3, can I find a replacement without buying full pot
www.villeroy-boch.com/.../faq.html?&...en..
https://pro.villeroy-boch.com/en/.../technical-data.html
Jul 05, 2014 | VILLEROY AND BOCH USA Villeroy n Boch...
Tank Cover
online by asking same question on web.
Mar 31, 2014 | Villeroy & Boch Villeroy-Boch Colani...
Villeroy and boch toilet parts
attach 2X4s behind it to ensure its stable. I had same problem but used that wood to reinforce it (covered with hardy board & paint) and reattached it and wall is very strong and toilet does not move.
Apr 27, 2013 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Hi i am looking for Villeroy & Boch seat product no: (9955 S1 01). Kindly, provide me Quotation
V & B US customer service number used to be 877-505-5350 it has been a while since I used it, but they were very helpful when I did. Hope this helps.
May 11, 2010 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Leaking water into bowl
Your question has been posted under the heading of Villeroy & Boch. If this is the brand you are working on then the flush valve is set up like the old Mansfield Fush valves and is replaced in the same way. But if VB is the brand you might try calling 877-505-5350 it is or was their US number. Hope this helps.
Mar 29, 2010 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
My Villeroy and boch toilet's water level inside the toilet is always low. I was seeing if there was a way to increase the level inside the toilet, not the tank.
Feb 09, 2010 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
My V and B toilet suddenly stopped flushing today, what's the problem?
It won't drain? Is the tank draining? Is the water turned off? Or is it just plugged up?
Jun 19, 2009 | Villeroy & Boch 6610 11 Subway...
Villeroy & boch flush mechenism needs to be replaced
This problem is either two things:
1/ The water inlet valve is letting by and going down the overflow pipe. (Connected to the main centre column). You can check this by taking off the lid off.
2/ Centre column seal at the base is letting by. You can unclick the centre column by pushing the two paddles either side.
Then lift out the centre column and check the grey washer at the base. You can turn this washer around and see if this solves - if not the column has probably has a part snap off.
You can get spares here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
May 27, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Home Logo
35 people viewed this question
Top Villeroy & Boch Home Experts
john h
Tom Chichester
Are you a Villeroy & Boch Home Expert? Answer questions, earn points and help others
