Nikkai video sender 5.8, picture on receiver tv but nothing on transmitter tv
Cannot get picture on tv1 but can get it on tv2 in other room at all with nikkai video sender 5.8. I have a tv without built in freeview, and use youview box at present, my old video sender has scart outlets so I connect tv to video sender by my main scart lead, then there are 4 more scart outlets to join freview box, dvd and video to video sender. Obviously I cannot do this with Nikkai video Sender, so do I put attached scart to tv and phono scart to you view box or do I need a scart changer to join tv to box then to youview box n then phono scart to dvd, in which case I will need to buy a dual scart box, I can get picture on 2nd tv in bedroom but obviously cant get anything on living room tv where transmitter is hope I haven't confused you
2 Suggested Answers
SOURCE: Can't set up my new Nikkai 5.8GHz video sender.
Could be that the Scart socket doesn't pass through the signals from the receiver. I had a Goodmans TV with Scart input which just didn't respond to the receiver. When I moved it to the Scart connector on my VCR it worked a treat.
Posted on Feb 03, 2009
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
I turned the living room tv on this morning and it is black and white and says no signal. The other tvs are working fine. I have turned it off and turned it back on still nothing
Hi my name is Mike Houston of DISH Network and I see youturned on the living room TV and it was black & white and had no signal.Depending if it's a Dual receiver and if the issue is TV1 or TV2 but there issome thing's you can check to make sure it is on the right channel. I will sendyou two links to help with the setup for both TV1 and TV2, if you have anymorequestions or concerns please e-mail me back at Michael.houston@dishnetwork.com;http://www.dishnetwork.com/SupportSection/bbs-screenand http://www.dishnetwork.com/SupportSection/black-blue-tv2.
Sep 04, 2011 | DISH Network 322 DTV Receiver
I'm in the room and using tv 2 on dvr but I see tv1 and don't know how to go back to tv 2. So what I'm trying to say is I'm watching what tv 1 is watching.
Himarcos_and_s, my name is Mike Houston of DISH Network and I was going over yourpost and with TV2 showing what's on TV1 you want to make sure the receiver isin dual mode and if that is the case please unplug the receiver for 10 secondsto reset the receiver and you will have your TV1 and TV2 showing differentprograms. If you have any questions please e-mail me at Michael.houston@dishnetwork.com.
Mar 22, 2011 | DISH Network Televison & Video
No picture and the fan will not stop running,
Are you receiving no picture on TV1 or TV2?
If it is on TV1 you will want to verify your television is on channel 3 or 4. In some cases with the VIP receivers it may be 65 or 72 as well. I would also suggest going through the inputs on the receiver. Most tvs would list it as a "tv/video", "source", or "input". You'll also want to make sure all connections are tight and secure. At last resort you can try a hard reset by unplugging the receiver for 10 seconds.
It no picture is on TV2, you will want to confirm what channel the TV should be on by using TV1. On TV1 go to Menu then press 6-1-5 and change TV2 to the channel showing in "TV2 out".
With the fan running that is completely normal as the DVR function is always in use. It always has the capability to be paused and to use the rewind function so the fan is always cooling the hard drive.
Nick Franta
DISH Network Customer Service
Feb 07, 2011 | DISH Network ViP622 DVR DTV Receiver /...
With 2 tvs you set to record on 1 and it records on 2 instead?records on the opposite tv
Hello, Matthew Gonzales with DISH Network here. The default setting in our receivers are to automatically record everything onto TV2. You can change the setting by pressing menu-8- 5 (preferences-record plus), then you can either disable the feature, or set it to record onto TV1. If the feature is disabled, the show will record at whichever TV the timer is set up on. If it is set to TV1, all timers will attempt to record on TV1 (unless TV1 already has a recording going on it then it goes to TV2). Hope this helps.
Matt
Jan 04, 2011 | DISH Network DVR-625 DTV Receiver /...
I have dish network and am trying to watch tv on my gateway plasma. how do i connect my satelite cable to plasma to get picture?
We would like to guide you through the connection process,but depending on what kind of receiver and TV you have this process may vary.Visit our "How to connect receiver" page here:http://www.dishnetwork.com/SupportSection/setup-receiver.
Once we have everything connected correctly, check what channel or input yourTV is currently on by powering the TV off then back on and noting the channelor input that appears on screen when the TV is powered on.
Steps for getting picture on TV1:
If you are using a Coax Cable to connect the receiver to TV1, check thereceiver's back panel for the output name. If your receiver has a "TVCH 3/4 out" (non-ViP Receiver): Tune TV to channel 3 or channel4, if it has "Home Distribution" output (ViP Receiver):Tune TV to channel 62 or 75. If using non-Coax (RCA,Component, or HDMI) to connect receiver to TV1, cycle through the inputs untilpicture appears (this information may appear on the remote sticker), mostTVs have a "TV/Video", "Input", or "Source" button.
Steps for getting picture on TV2:
Access "Modulator Setup" from TV1 by pressing "menu"then 6-1-5. Tune TV2 to the channel that appears under "TV2 Out" onscreen. If still no picture, change the "TV2 Out" mode fromAir to Cable, or if it's already on Cable, change it to Air. Then change thechannel of TV2 to what is now displayed under "TV2 Out".
If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. It may take up to 5 minutes for the reset processto be completed. If you still are not getting a picture, connect anothercomponent (VCR, DVD Player, etc.) to the same TV, using same cable, same input,and same channel to see if it works. If it works give us a call at1-800-333-DISH (3474) for additional troubleshooting, if you don't get apicture with the other component, replace the cable.
Hope this steps help, and thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
Dec 02, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Can't get signal on tv2
Hello! Daniel Busa with Dish Network customer service. The first thing I would do is try unplugging the reciever for ten seconds, then plugging it back in. If that doesnt do the trick, make sure the tv is on ch 60 or 73. If it goes to 73 and there is no picture, go to tv1 hit menu 6-1-5 under tv2 out it will say 60 or 73, you'll want it set to 73 highlight cable and hit select. If the tv doesn't go above 69 make sure tv2 is set to air 60 don't change tv1's setting during any of this.
Nov 26, 2010 | DISH Network 322 DTV Receiver
Nikkai 2727 Video sender will not send signals from my sky+ box. The scart lead is plugged into the Video out, but even when i plug it into the TV out it still doesnt work. I know the Transmitter and...
check that you have the sender plugged into the sky box and the receiver into the required tv and not the other way round. The wrong way round still allows the controller to change channels but you will see nothing also ensure that both sender and reciever are on same channel 1 to 4
Jan 24, 2010 | Panasonic Televison & Video
Problem with DISH DVR 625
You can accomplish this by either going to the specific TV and selecting the record option at the time the program is about to come on or you can press menu-8-5 and change the record preferences. You can either set the DVR to record programs to the TV2 location by default or TV1 by enabling the record plus feature. In dual mode without record plus enabled all programs you select to record default to the tuner you are viewing e,g, if watching tv1 and selecting to record a program in the future it will record to the tv1 location.In single mode all recordings default to tv2 so you can continue to watch live tv from tv1. I hope this answers your question and thanks for using Fix Ya. Let me know if I can further assist you.
Dec 14, 2008 | DISH Network DVR-625 DTV Receiver /...
Nov 18, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
